joe Guest
27-10-2003, 8:23 Subject: Audi A3 Engine Stalls: Common Problem & Fix? |
Hello, I'm having an issue with my Audi A3, manufactured in February 1997, with a 66kW TDI engine and 70,000 km on the odometer. After driving approximately 2km from a cold start, the engine cuts out. After a short pause, it starts again and runs normally.
Could it be the diesel filter? All service intervals have been followed, but due to the low mileage, only the maintenance package for drivers who use their car less frequently has been performed.
The diagnostic tool shows no errors. Only the central locking system reported error code 1367.
Could that be related?
'Something else I've noticed is that the tachometer immediately shows zero when the engine is turned off, even though it should still be driven by the transmission in neutral. Does this indicate a power failure?'
I'm quite at a loss!
What should I change?
Diesel filters.
Relay for fuel injection pump.
X-Contact Relay.
Translated on 28-07-2026, 12:54.
timon Guest
27-10-2003, 8:29 Subject: Audi A3 Engine Stalls: Common Problem & Fix? |
There might be an issue with the immobilizer (power failure). Please try using the search function.
Klaus.
Translated on 28-07-2026, 12:55.
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
27-10-2003, 8:33 Subject: Audi A3 Engine Stalls: Common Problem & Fix? |
Check relay 109.
Translated on 28-07-2026, 12:56.
Profile PM WWW Garage |
joe Guest
27-10-2003, 8:45 Subject: Audi A3 Engine Stalls: Common Problem & Fix? |
Hello Rainer,
'Silly question, what is the number of the relay designated as '109' in an Audi A3? The relays are labeled from I to VI and numbered from 1 to 12.'
27-10-2003, 9:02 Subject: Audi A3 Engine Stalls: Common Problem & Fix? |
Hello, I have no idea.  However, due to the large print "109", it is impossible to miss it.
Translated on 28-07-2026, 12:57.
donalexo Profi-Schrauber
Joined: 01/08/2003 Posts: 695 Karma: +0 / -0 Location: Würzburg
27-10-2003, 12:50 Subject: Audi A3 Engine Stalls: Common Problem & Fix? |
Hello Joe!
Please note that the location of relay 109 in the A3 is not easily accessible. The relay is located on a relay holder underneath the steering column. To access it, you need to remove the lower dashboard panel on the driver's side.
Identifying the relay itself is very easy. As Rainer already mentioned, it has a large "109" printed on it.
The relay locations you mentioned sound to me more like the ones that are typically housed in the circuit breaker box.
Alex. AUDI A3 1.9 TDI, EZ 12/96, ursprüglich MKB AGR, umgebaut zum AHF mit GT1749V-Lader, verkauft mit 250tkm
Touran 1.9 TDI, EZ 09/2004
Translated on 28-07-2026, 12:58.
joe Guest
28-10-2003, 7:34 Subject: Audi A3 Engine Stalls: Common Problem & Fix? |
Hello, relay 109 found and resoldered, the other relays checked, all cable terminal screws tightened. Test drive completed, the engine no longer stalls.
Whether I have actually found the error will become clear in the next few days.
I will keep you updated.
Translated on 28-07-2026, 12:59.
