Audi A3 Engine Stalls: Common Problem & Fix?
joe
Post27-10-2003, 8:23    Subject: Audi A3 Engine Stalls: Common Problem & Fix? Quote
Hello, I'm having an issue with my Audi A3, manufactured in February 1997, with a 66kW TDI engine and 70,000 km on the odometer. After driving approximately 2km from a cold start, the engine cuts out. After a short pause, it starts again and runs normally.
Could it be the diesel filter? All service intervals have been followed, but due to the low mileage, only the maintenance package for drivers who use their car less frequently has been performed.
The diagnostic tool shows no errors. Only the central locking system reported error code 1367.
Could that be related?
'Something else I've noticed is that the tachometer immediately shows zero when the engine is turned off, even though it should still be driven by the transmission in neutral. Does this indicate a power failure?'
I'm quite at a loss!
What should I change?
Diesel filters.
Relay for fuel injection pump.
X-Contact Relay.
Translated on 28-07-2026, 12:54.
timon
Post27-10-2003, 8:29    Subject: Audi A3 Engine Stalls: Common Problem & Fix? Quote
There might be an issue with the immobilizer (power failure). Please try using the search function.
Klaus.
Translated on 28-07-2026, 12:55.
Karma: +807 / -0   Thank you, like it!
Post27-10-2003, 8:33    Subject: Audi A3 Engine Stalls: Common Problem & Fix? Quote
Check relay 109.
Translated on 28-07-2026, 12:56.
joe
Post27-10-2003, 8:45    Subject: Audi A3 Engine Stalls: Common Problem & Fix? Quote
Hello Rainer,
'Silly question, what is the number of the relay designated as '109' in an Audi A3? The relays are labeled from I to VI and numbered from 1 to 12.'
Post27-10-2003, 9:02    Subject: Audi A3 Engine Stalls: Common Problem & Fix? Quote
Hello, I have no idea. icon_lol.gif However, due to the large print "109", it is impossible to miss it. icon_cool.gif
Translated on 28-07-2026, 12:57.
donalexo
Post27-10-2003, 12:50    Subject: Audi A3 Engine Stalls: Common Problem & Fix? Quote
Hello Joe!
Please note that the location of relay 109 in the A3 is not easily accessible. The relay is located on a relay holder underneath the steering column. To access it, you need to remove the lower dashboard panel on the driver's side.
Identifying the relay itself is very easy. As Rainer already mentioned, it has a large "109" printed on it.
The relay locations you mentioned sound to me more like the ones that are typically housed in the circuit breaker box.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 28-07-2026, 12:58.
joe
Post28-10-2003, 7:34    Subject: Audi A3 Engine Stalls: Common Problem & Fix? Quote
Hello, relay 109 found and resoldered, the other relays checked, all cable terminal screws tightened. Test drive completed, the engine no longer stalls.
Whether I have actually found the error will become clear in the next few days.
I will keep you updated.
Translated on 28-07-2026, 12:59.
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat TDI: Engine Stalling After Cold Start On-Board Diagnostics (OBD)
No new posts Engine Stalls After Starting: Polo 6N2 1.4 TDI (AMF) On-Board Diagnostics (OBD)
No new posts Engine Stalls After Starting: Troubleshooting Guide Diesel Engine Technology
No new posts Engine Stalling: Troubleshooting & Fixes Diesel Engine Technology
