VP37 Set Screws: Installation & Guide
Post30-10-2003, 16:02    Subject: VP37 Set Screws: Installation & Guide Quote
Hi.
There are these hollow screws, also available in a "vertical" configuration, with the outlet on the axis of rotation, for the inlet and outlet sides.
Does anyone know their part number? The VW computer doesn't show anything, it only lists one version.
I now have two right angles, but I need the others.
http://people.freenet.de/golf-schrauber/Kran_Oese.jpg
Translated on 09-10-2026, 17:45.
Wolfgang, syncro16
Post01-11-2003, 23:51    Subject: VP37 Set Screws: Installation & Guide Quote
Hello Martin,
I was also surprised by that. My intake screw was vertical, but the catalog only shows the right-angled version. I still have my vertical intake screw; I could give it to you if I can find it.
Hello.
Wolfgang.
Translated on 09-10-2026, 17:46.
Post02-11-2003, 20:18    Subject: VP37 Set Screws: Installation & Guide Quote
Hi Wolfgang,
That would be great!
I actually built an AFN cover for my 1Z, and it's now pressing on the 1Z cable, which is why I already bought some AFN cables, but they don't have the connectors new_cry.gif.
And I need exactly one vertical one.
If you find it, please let me know.
Greetings.
Translated on 09-10-2026, 17:47.
Wolfgang, syncro16
Post06-11-2003, 18:26    Subject: VP37 Set Screws: Installation & Guide Quote
Hello m,
'I've finally found the supply line. It's a molded plastic line with rubber hoses crimped on both sides, and of course, the straight nipple. The VW part number is 1H0 130 307 AC, which is also listed in the catalog, but it's only sold as a complete unit, so the individual nipple isn't included.'
What do you need right now? Just the nipple, the entire pipe, or also the return line?
Hello.
Wolfgang.
Translated on 09-10-2026, 17:48.
Post07-11-2003, 13:24    Subject: VP37 Set Screws: Installation & Guide Quote
Let's arrange that via email.
My address is listed above.
Translated on 09-10-2026, 17:49.
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Injector sizes for TDI engines with distributor injection... Technical Data
No new posts ESP VP37 Diesel Engine Technology
No new posts Golf 3 TDI 1Z/ VP37 Diesel Engine Upload
No new posts VP37 Issue: AFN in T3 Van On-Board Diagnostics (OBD)
No new posts Check VP37 Diesel Engine Technology
