Fuel injectors & PD elements
Thomas
Post15-11-2003, 12:14    Subject: Fuel injectors & PD elements Quote
Now that it is clear, as described in the technical article, that with a VEP-TDI engine, it is possible to replace the fuel injectors of a 66 or 81 kW TDI engine with a slightly larger version to achieve higher engine performance values.
I wonder if it's that "easy" with PDs as well?
Apart from the price and installation costs!
If so, that would certainly be an alternative to tuning boxes, etc.
Has anyone perhaps done something like that before?
Greetings.
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 09-07-2026, 5:16.
DaBibo
Post15-11-2003, 18:51    Subject: Hmm.. Quote
The PD elements are already identical, which is also the reason why PD engines are so easily tunable via chip. The new 2.0 16V TDI might have different...
Translated on 09-07-2026, 5:17.
Nuckelpinne_72
Post15-11-2003, 22:29    Subject: Fuel injectors & PD elements Quote
Apparently, neither the PD (Positive Displacement) elements nor the integrated nozzles are identical across all PD units, as there have always been ongoing developments. For example, the 'ks' nozzles in the ARL and AXR models improved flow and emission values.
Thomas wrote:
Now that it is clear, as described in the technical article, that with a VEP-TDI, one can replace the fuel injectors of a 66 or 81 kW TDI with the next larger variant to achieve slightly higher engine performance values,
frage ich mich, ob das bei den PD´s auch so 'einfach' geht?
Based on everything I've read so far, it's not possible to use different nozzles in a PD (positive displacement) element. This is probably because the nozzles are permanently bonded during manufacturing, or because only the original nozzle fits into each specific element. I'm also curious why they can't be replaced.
Even in descriptions of very expensive and complex tuning modifications for PD engines, there was never any mention of replacing the PD injectors. Other measures are likely to be significantly more cost-effective, considering the expense of replacing the PD injectors.
Ich stell mal die Frage in die Runde, ob denn die PD-Elemente im 74KW AXR identisch mit denen im 110KW ARL sind, da ja in beiden Typen ks-Düsen stecken. Wenn ja, dann sollten zumindest die PD-Elemente im AXR ein Chiptuning des Motors wohl gut verkraften, oder ? icon_smile.gif
Greetings, Marcus.
Translated on 09-07-2026, 5:19.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Replacement of injector nozzles/holders on a VP-TDI Troubleshooting & Guides
This topic is locked, you cannot edit or reply. pd-Elements Adjustment: 225° vs. 180° Diesel Engine Technology
No new posts BKD Seats for PD Elements Diesel Engine Technology
No new posts Dichtungssatz PD Elemente Diesel Engine Technology
No new posts PD-Elemente Unterschied???? Diesel Engine Technology
