B4 VR6 Kombi Instrument Cluster for 1Z TDI
WarLord
Post06-11-2003, 22:38    Subject: B4 VR6 Kombi Instrument Cluster for 1Z TDI Quote
Can you install a combination instrument with the MFA (Multifunction Display) from a Passat 35i B4 VR6 into a Passat TDI with a 1Z engine? I'm asking because there are many combination instruments for the VR6 offered on eBay, but none for the TDI. The only thing I would have to replace would be the bezel with the gauges, since the speedometer and tachometer readings wouldn't match. Can the combination instrument be coded to match a 4-cylinder engine? If not, I'll be extremely frustrated and will probably buy a VR6 soon and convert it to turbo. icon_wink.gif
Best regards, WarLord.
Translated on 28-09-2026, 7:58.
DocSnydor
Post07-11-2003, 8:00    Subject: B4 VR6 Kombi Instrument Cluster for 1Z TDI Quote
'No, Warlord, that won't work. You need to pay attention to the 'distance number' (is that what it's called?), and that's definitely different for the VR6 compared to the TDI. Then the tachometer would go way too high...'
And it's not possible to reprogram it. The instrument cluster isn't even capable of diagnostics... icon_sad.gif
Sorry for the bad news icon_wink.gif.
Translated on 28-09-2026, 7:59.
WarLord
Post07-11-2003, 9:55    Subject: B4 VR6 Kombi Instrument Cluster for 1Z TDI Quote
Well, then the TDI engine can suddenly rev up to 7,000 RPM or more. *g* I'm not a fan of that. There are lots of VR6 instrument clusters on eBay, but none for a TDI (not even from a T4). By the way: How do you adjust the mileage if you can't even code the instrument cluster?
Translated on 28-09-2026, 8:00.
Albrecht
Post07-11-2003, 18:54    Subject: B4 VR6 Kombi Instrument Cluster for 1Z TDI Quote
I'm having the same problem.
But:
Can't you simply attach the LCD with the MFA (Multifunction Display) behind the TDI speedometer instead of just a clock? Or are there missing connections on the film again?
mfA
Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
WarLord
Post07-11-2003, 20:50    Subject: B4 VR6 Kombi Instrument Cluster for 1Z TDI Quote
I've been wondering about that too. But I have an idea now: What if we read the software (from the TDI instrument) and then write it to the VR6 instrument? You would need an EPROM burner for that.
Translated on 28-09-2026, 8:01.
No new posts Software error in the instrument cluster - workshop action Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo Combo Instrument Cluster, 10.99-09.2001 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo combination instrument panel, 1998 to 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 8E Kombi Instrument 2.5 TDI AKE On-Board Diagnostics (OBD)
No new posts Combination Instrument: Features & Benefits On-Board Diagnostics (OBD)
No new posts A4 B5 Quattro Instrument Cluster On-Board Diagnostics (OBD)
No new posts GRA Indicator in Dashboard: Meaning & Troubleshooting Diesel Engine Technology
