Oil Pan Removal: How-To Guide
Cheffe
Post11-11-2003, 21:18    Subject: Oil Pan Removal: How-To Guide Quote
I'm having a problem with a Passat Variant B5, manufactured in 1998, with engine code AFN.
The oil pan gasket is leaking, and now the oil pan needs to be removed.
However, there's a problem: the axle runs underneath the oil pan. It can't be that we have to remove the axle or lift the engine so high that we can remove the oil pan.
The REP guidelines do not mention anything about expansion.
Does anyone have any advice?
Boss.
Translated on 09-10-2026, 17:18.
haehnlein
Post11-11-2003, 23:06    Subject: Oil Pan Removal: How-To Guide Quote
Hi Boss,
I don't know how it is with your Passat, but with my old one (a 1985 TD), the axle had to be removed because the engine was installed longitudinally. In your case icon_confused.gif.
____________
Kein Auto mehr!
Translated on 09-10-2026, 17:19.
Cheffe
Post12-11-2003, 6:24    Subject: Oil Pan Removal: How-To Guide Quote
Yes, that's right. In the B5, the engine is also mounted longitudinally, whereas in the B4, it was mounted transversely. That made it easier to remove the engine in the B4.
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8E Oil Pan Removal: Guide & Instructions Diesel Engine Technology
No new posts Oil Sump Spray Tube: Causes & Solutions Diesel Engine Technology
No new posts Oil Pan Gasket 1Z Diesel Engine Technology
No new posts 2.5 TDI: Parts found in the oil pan Diesel Engine Technology
