Customizing WFS2?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Silver78
Post08-02-2004, 21:19    Subject: Customizing WFS2? Quote
I'm new to this forum, and I've already used the search function to see if I could find anything relevant, but unfortunately, I haven't found anything useful so far.
Okay, I want to replace my old speedometer (part number 3B0 919 881?) with a new one (part number 3B0 920 842 Ax) (this is a Passat 3B TDI). I need to adjust the WFS (Vehicle Status Field) for this, and since both speedometers have WFS2, it should be possible. My question is, can I do this myself using VAG-COM? I have the 4-digit PIN code for the original speedometer, but I don't have it for the new one. However, I've been told that it can be read from the EEPROM. Can I calibrate the new speedometer myself with these conditions, or do I have to go to VW?
Sure, here's the translation:
'Best regards, Silver78'
joergs
Post09-02-2004, 13:17    Subject: Customizing WFS2? Quote
Check this out.
http://www.vcds.shop/index_2.html
Then, look at examples, and you should be able to find something to read for further information.
Silver78
Post09-02-2004, 21:29    Subject: Customizing WFS2? Quote
Well, unfortunately, I'm missing the login code for the speedometer that is supposed to be installed... icon_cry.gif
joergs
Post09-02-2004, 22:47    Subject: Customizing WFS2? Quote
which login code?
If you're referring to the PIN, you can obtain it from your local Volkswagen workshop. If you're having trouble with the login, it might also be related to the software from VAG-COM.
Silver78
Post09-02-2004, 22:50    Subject: Customizing WFS2? Quote
Yes, I mean the 4-digit PIN code that was used with the WFS2. Well, if it comes to it, I guess I'll have to go to VW after all, which is something I was actually trying to avoid.
joergs
Post09-02-2004, 22:55    Subject: Customizing WFS2? Quote
You'll probably have to. Take everything with you, including your ID, just in case they ask questions. And don't let them brush you off. They have to give it to you if you can prove it's your property.
mersente
Post10-02-2004, 0:17    Subject: Customizing WFS2? Quote
Hello, you will probably have to contact your friendly dealer, as they can request the 7-digit code (in reality, it's still a 4-digit code, but it's linked to the date and workshop code).
Unfortunately, your friend doesn't have a way to obtain a 4-digit code for you.
The only solution: diagnostic tools.
Then you don't need to go to the friendly one, but that will be more expensive if you don't do that often.
Silver78
Post10-02-2004, 21:56    Subject: Customizing WFS2? Quote
Yes, and if I have the 4-digit code, can I then customize it myself? If so, how should I proceed?
mersente
Post11-02-2004, 23:20    Subject: Customizing WFS2? Quote
Unfortunately, I'm not familiar with VAG-com, but please check address 17 to see if there's anything listed about adjusting the key or adapting the immobilizer to the engine control unit.
Okay, so first, you would need to adapt the immobilizer to the engine control unit, and then you would need to program the keys.
(Maybe someone could lend me a VAG-COM device so I can test it.)
joergs
Post12-02-2004, 8:12    Subject: Customizing WFS2? Quote
In the link I posted above, the WFS settings are described in detail. You should be able to find the key adjustments using the search function here!
Silver78
Post12-02-2004, 21:35    Subject: Customizing WFS2? Quote
Okay, thanks, everything worked out.
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjust Consumption Display Diesel Engine Technology
No new posts Adjusting the {ELECTRO_SERVO} in the 3C/1K setup? Transmission, Chassis, Body & Interior
No new posts MSG und KI anpassen 115PS TDI VAG On-Board Diagnostics (OBD)
No new posts ASZ Drehmomentkurve anpassen? Diesel Engine Technology
