jcee Guest
03-09-2003, 10:44 Subject: Auxiliary Heater for ARL: Best Options |
Hi, I've already looked at the Webasto website, but I couldn't find anything there.
My friend told me that only certain auxiliary heaters fit in the 110kW TDI (probably due to space constraints). Does anyone have a list or information about which models are compatible? What type of heater would that be?
Translated on 04-10-2026, 19:25.
Gremlin Guest
03-09-2003, 15:36 Subject: Auxiliary Heater for ARL: Best Options |
Guys... pay attention...
www.webasto.de
'quote:'
Questions and Answers:
Do you have any questions about parking heaters?
Hotline: 0800/1234577
'The quick brown fox jumps over the lazy dog.'
CU Gremlin.
Translated on 04-10-2026, 19:26.
jcee Guest
03-09-2003, 17:53 Subject: Auxiliary Heater for ARL: Best Options |
Sure, thanks for the tip.
I'm also looking for some 'insider tips' because I didn't just want to gather some sales information. Otherwise, I wouldn't have asked Dieselschrauber.de  .
Perhaps I can also find older models that I can purchase on eBay, etc.
Translated on 04-10-2026, 19:27.
Gremlin Guest
04-09-2003, 7:32 Subject: Auxiliary Heater for ARL: Best Options |
guy...
What do you think the purpose of the hotline at Webasto is?
That's exactly the kind of question I'm here for.
Which heater is suitable for my car?
What parts do I need for this?
If you call them (or send them an email), you'll find that they provide competent information without immediately trying to sell you a heating system.
They even call you back just to tell you how much power the FFB receiver consumes.
CU Gremlin.
Translated on 04-10-2026, 19:28.
Lucas Guest
04-09-2003, 9:04 Subject: Auxiliary Heater for ARL: Best Options |
@jcee
I can't tell you exactly which auxiliary heater fits your vehicle model, but it might also be possible to modify a heater to fit. In that case, you would have to build some of the angles and brackets yourself. I didn't have any problems with the installation (in my Audi 80), although there is naturally more space  . I installed a TermoTop S (from eBay).
You should be aware that heaters with a separate fuel pump may require less space. However, the pump must then be installed close to the fuel tank. In my case, I had to tap into the supply line, not the return line.
Translated on 04-10-2026, 19:29.
christians Profi-Schrauber
05-09-2003, 20:10 Subject: Auxiliary Heater for ARL: Best Options |
Webasto also offers heaters where you can separate the water pump from the actual heating unit. This might be useful in certain situations.
On the other hand, the connections at Eberspächer and Webasto are generally somewhat different.
Will they really recommend a competitor's product to you if you have installation problems with a Webasto product?
If the installation instructions become too extensive, I would suggest asking elsewhere.
I would have had an easier time with the Eberspächer system in my car, although I am otherwise satisfied with the Webasto heating system. Gruß Christian
Translated on 04-10-2026, 19:31.
jcee Guest
05-09-2003, 20:43 Subject: Auxiliary Heater for ARL: Best Options |
Thank you for the answers...
'That's what I mean. Someone once told me that not all diesel heaters fit in the 110kW diesel engine bay (due to space constraints). I'm also open to considering other brands, like Eberspacher. I just wanted to get a little more information before I spend my money on eBay.'
Translated on 04-10-2026, 19:32.
bora_tdi Guest
12-11-2003, 23:41 Subject: Best Stand Heater for ARL Cars |
Today, I had a Webasto auxiliary heating system installed in my Bora TDI 110kw (engine code ARL) diesel.
It is a Thermo TOP E with a timer (model 1533) that has 3 time settings.
The Bosch service required one working day to install it.
The price for the STH with pre-selection dial and installation is €1300!
Translated on 04-10-2026, 19:33.
