VW Passat TDI: 96kW, 2WD, Webasto Heater
MikeF
Post18-11-2003, 15:17    Subject: VW Passat TDI: 96kW, 2WD, Webasto Heater Quote
Hello everyone!
'I'm getting my SH (auxiliary heater) from Webasto tomorrow. It's a Tele Thermo Top C+ with all the installation accessories. My question is about the exhaust pipe that goes into the tank fitting. Does anyone know what it looks like specifically, and whether it's easy to drill the hole as described in the instructions? How do you disassemble the fitting (on a 2WD model, which has it in the floor of the trunk)? It's hard to see from the installation pictures. Do you have to remove the entire pump, or is it enough to just remove the cover with the hoses? I believe the exhaust pipe is rigid, right? Won't that be somewhat in the way when you reinstall the cover?'
Please provide information.
Thank you.
Greetings.
Translated on 23-07-2026, 23:00.
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts PD Motor Workshop: 96kW, Servo Return Hose Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI PD Passat 3BG: 96kW Performance & Acceleration Diesel Engine Technology
No new posts Webasto/ClimaTronic D1 Contact: Help Needed! Diesel Engine Technology
No new posts Webasto Heater Diagnostics: Online Software Found On-Board Diagnostics (OBD)
No new posts TDI 96kW: Top Speed 130 km/h Diesel Engine Technology
