x world one Blaumann
17-09-2005, 15:39 Subject: Idle speed and emissions test |
Today I took my Golf3 1Z for a used car inspection because my girlfriend wants to take over the car. We also had an emissions test done at the same time.
The following phenomenon occurred:
The minimum required speed was not reached, and the maximum speed achieved was 4500 RPM. A K-value of approximately 0.7 was observed, which the inspector considered to be very good.
Why is the RPM limited to 4500 RPM, or why doesn't it rev higher?
Should I be worried about the engine now?
Thank you.
Spritmonitor
Translated on 19-07-2026, 2:32.
18-09-2005, 14:35 Subject: Idle speed and emissions test |
Therefore, it's a good idea to bring a laptop to the TÜV (technical inspection center), so that if necessary, you can "listen in" during the second measurement.
However, the k-value is meaningless because the initial test should be performed "very slowly" to reach the rated speed. The actual measurements must be taken within 1 or 1.5 seconds from idle to rated speed.
Either you have a strict examiner who immediately demands full throttle, or one who is clueless and doesn't realize that values obtained with gentle acceleration are always lower than those required by the regulations.
Translated on 19-07-2026, 2:34.
Profile PM Garage |
18-09-2005, 21:07 Subject: Idle speed and emissions test |
He probably did the measurement three times. The first one was really "slow." Then he pushed down quite hard, and my girlfriend got really scared. Anyway, there was a pretty big black mark on the floor of the indoor pool area. I unfortunately didn't have my laptop with me. But I'll check the RPM myself again later. But it might be about right, I think.
Spritmonitor
Translated on 19-07-2026, 2:35.
18-09-2005, 23:09 Subject: Idle speed and emissions test |
Please include the numbers 3, 8, and 11 in your personal log entry.
Then it would be nice to see how and why it shuts down.
Greetings.
Translated on 19-07-2026, 2:36.
Profile PM Garage |
engl Guest
21-09-2005, 11:34 Subject: Idle speed and emissions test |
A k-value of 0.7 is normal. The idle speed will adjust itself before you need to make any adjustments to the car. Find a testing facility that can correct the test speed accordingly (they are allowed to do so!).
Translated on 19-07-2026, 2:37.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
21-09-2005, 11:51 Subject: Idle speed and emissions test |
Here's a quick note: During my last inspection, the inspector attached a body sound sensor (is that what it's called?) to the engine. It was funny because depending on where he attached the sensor (the device has a magnet), different RPM readings were displayed  .
Well, eventually things worked out.
Profile PM WWW Garage |
engl Guest
21-09-2005, 18:34 Subject: Idle speed and emissions test |
'@Rainer: Yes, this problem sometimes occurs, seemingly randomly, especially with BMW six-cylinder engines, which can sometimes provide completely erratic RPM readings; that's where the inspector comes in!'
Translated on 19-07-2026, 2:38.
03-10-2005, 11:46 Subject: Idle speed and emissions test |
Okay, I finally managed to log in.
Okay, the rev limiter seems to be working correctly. Although, I wouldn't call it "rev limiting"; it just stops accelerating. It's not like my gasoline cars, which then aggressively hit the rev limiter.
According to the VAG-Com diagnostic tool, the maximum engine speed in third gear is 4700 RPM.
I have attached two log files from the desired measurement blocks.
According to the k-Power tool, the Golf has a power output of either 64 kW and 225 Nm, or 66 kW and 235 Nm. These are values from two measurements taken on the same track, in both directions. In the log with the higher power output, I wasn't able to let the car coast for as long.
Well, that doesn't really have anything to do with the problem.
| Description: |
 Download |
| File name: |
20051003_LOG-02-003-008-011.CSV |
| File size: |
3.72 KB |
| Downloaded: |
412 times |
| Description: |
 Download |
| File name: |
20051003_LOG-01-003-008-011.CSV |
| File size: |
4.51 KB |
| Downloaded: |
488 times |
Spritmonitor
Translated on 19-07-2026, 2:39.
03-10-2005, 12:36 Subject: Idle speed and emissions test |
x world one wrote: | | According to VAG-Com, the maximum RPM in third gear is 4700 RPM. | . . . and when the car is stationary, the engine will still rev slightly higher because it no longer has any driving resistances to overcome.
You can achieve an approximately realistic idle speed, similar to what you'd get during an emissions test (AU), only when driving in third gear on a downhill slope, where the car would naturally roll down at around 100 km/h!
Translated on 19-07-2026, 2:41.
Profile PM Garage |
Manuel Thomas Guest
03-10-2005, 17:02 Subject: Idle speed and emissions test |
Was your engine perhaps running in a limp-home mode? For me, with the system not in limp-home mode, the oil turbidity was 0.55 at an adjusted speed of 5,150 RPM, and in limp-home mode it was 1.97 m and 4,750 RPM.
Manuel.
Translated on 19-07-2026, 2:42.
