VW Passat TDI: 96kW, 2WD, Webasto Heater
MikeF
Post18-11-2003, 15:17    Subject: VW Passat TDI: 96kW, 2WD, Webasto Heater Quote
Hello everyone!
'I'm getting my SH (auxiliary heater) from Webasto tomorrow. It's a Tele Thermo Top C+ with all the installation accessories. My question is about the exhaust pipe that goes into the tank fitting. Does anyone know what it looks like specifically, and whether it's easy to drill the hole as described in the instructions? How do you disassemble the fitting (on a 2WD model, which has it in the floor of the trunk)? It's hard to see from the installation pictures. Do you have to remove the entire pump, or is it enough to just remove the cover with the hoses? I believe the exhaust pipe is rigid, right? Won't that be somewhat in the way when you reinstall the cover?'
Please provide information.
Thank you.
Greetings.
Translated on 23-07-2026, 23:00.
No new posts Standheizung in Passat 3BG einbauen Troubleshooting & Guides
No new posts PD Motor Workshop: 96kW, Servo Return Hose Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 111kW AHY, auxiliary heater defective Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 96kW TDI PD in a Passat 3BG and strong acceleration (wet) Diesel Engine Technology
No new posts WEBASTO and CLIMAtronic Contact D1 - PLEASE HELP!!! Diesel Engine Technology
No new posts Diagnosis program for WEBASTO heaters found online On-Board Diagnostics (OBD)
No new posts TDI 96kW: Top Speed 130 km/h Diesel Engine Technology
