smith2 Guest
09-12-2003, 12:38 Subject: Audi Service Reset: Codes & Instructions |
Hello everyone,
I'm having a problem with an Audi A4 sedan, manufactured in 1996.
I tried to reset the service interval display according to the instructions posted here in the forum.
I am using VAG-VOM. While I can enter values for channels 5 to 8, the display still shows the service message!
Could it be because I didn't enter the values with 5 digits?
What else could be the cause? The adapter definitely works, otherwise I wouldn't be able to access the control units.
Then I have two error codes that I can't identify.
17736 and 17735.
In parallel, he also had this issue:
00561 - Mismatch.
15-00 - Adaptation limit (add) exceeded.
Is there a general overview of error codes available, without needing to know the specific combination of engine, transmission, and control units?
Thank you for your help.
cu smith2
Translated on 28-08-2026, 4:57.
Bertil Profi-Schrauber
09-12-2003, 14:47 Subject: Audi Service Reset: Codes & Instructions |
smith2 wrote: | Hello everyone,
I tried to reset the service interval display according to the tip here in the forum. |
if you tell me where you got the values for your car? Under https://community.dieselschrauber.org/en/viewtopic.php?t=3138, the A4 was only available from 1997 onwards. If yours is a 1996 model, then it's possible that there's a different procedure.
Or is your car only registered in 1996, but manufactured in 1997 (which can be identified by the vehicle identification number)? Gruß Bertil
Translated on 28-08-2026, 5:00.
smith2 Guest
09-12-2003, 16:14 Subject: Audi Service Reset: Codes & Instructions |
Hi Berti,
According to this table, these values are valid for the A4 model up to 1997. The table heading is:
In my opinion, that's incorrect, because the table (left column) indicates 'until 1997'.
Welche Werte habe ich woher? Wie meinst du das? What are the error codes?
How can I identify that from the vehicle identification number (VIN)?
cu smith2
Translated on 28-08-2026, 5:01.
09-12-2003, 18:39 Subject: Audi Service Reset: Codes & Instructions |
My name is Berti l.
Quote: |
According to this table, these values are valid for the A4 model up to 1997. The table heading is...
In my opinion, that's incorrect, because the table (left column) indicates "until 1997".
97> means 97 and above, not up to 97!
Quote: |
What values are you referring to, and where did you get them from? What do you mean?
What values you want to use for your car when resetting the service interval. When I created the program, I didn't have any values for the A4 from 1996. That's why your car isn't in the table. That's why I asked you where you got the correct values. I didn't have any.
I also noticed while creating the table that MJ96 is missing.
Das ist mir schon klar ... Sure, here is the translation of the text from German to English:
"Explanation see above."
Quote: |
How can I tell that from the vehicle identification number? |
Here you can decode the vehicle identification number and thus determine the model year. Gruß Bertil
Translated on 28-08-2026, 5:03.
smith2 Guest
09-12-2003, 20:09 Subject: Audi Service Reset: Codes & Instructions |
Hello Bertil,
Thank you for your kind and thoughtful way of phrasing your responses.
The values I got are from autointern, and they are probably incorrect.
If you feel like my questions are bothering you, then just don't answer.
This forum is known for its great willingness to help, offered in a friendly manner.
I still prefer a factual and objective writing style.
Thank you for your great tips.
cu
smith2
Translated on 28-08-2026, 5:05.
09-12-2003, 20:22 Subject: Audi Service Reset: Codes & Instructions |
smith2 wrote: |
Sorry, I think you've misunderstood something.
Ich fühle mich nicht belästigt, sondern habe nur klargestellt das in meiner Tabelle das MJ96 nicht behandelt wird. Daher hab ich auch gefragt wo du die Werte her hast (was du ja auch jetzt beantwortet hast ... D(Thank you).
I'm not sure what aspects of my questions or answers are supposedly lacking in objectivity.
You asked clear questions and received clear answers, and I certainly didn't insult you.
It should be clear to everyone that I will defend myself against any defamation of my name. Gruß Bertil
Translated on 28-08-2026, 5:06.
09-12-2003, 20:33 Subject: Audi Service Reset: Codes & Instructions |
Okay, let's just forget about it and start over.
Can you enter the values into the corresponding adaptation channels?
Do they remain stored, or after entering the data and reading it again, are the old data displayed instead?
If the old data remains, there might be a problem with the communication to the combined system. Someone had a similar issue with a Passat not long ago, as far as I remember.
P.S.: I currently have no idea what the error codes mean either. Gruß Bertil
Translated on 28-08-2026, 5:08.
09-12-2003, 21:02 Subject: Audi Service Reset: Codes & Instructions |
Hi smith2,
Take a look and see if anything appeals to you.
/viewtopic.php?t=3922&highlight=service+problems
I'm sorry, but I cannot provide a translation without the text you would like me to translate. Please provide the text from the URL you mentioned, and I will be happy to translate it for you.
After there were some misunderstandings there as well, it turned out to be a completely different mistake:
"Hello,"
After a long search, the error has now been found.
A contact problem on the connector of the cable for the instrument cluster. After a new timer contact connector was crimped on, the reset was possible exactly as I had tried before. Apparently, the connection was not making a good contact due to the poor connection. Gruß Bertil
Translated on 28-08-2026, 5:09.
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
09-12-2003, 21:04 Subject: Audi Service Reset: Codes & Instructions |
Could it be that the vehicle is not a diesel but a gasoline-powered car?
If so, then check the fuel pressure and the fuel injectors (in case of error code 561). Tschüss
Michael II
Translated on 28-08-2026, 5:11.
smith2 Guest
09-12-2003, 21:15 Subject: Audi Service Reset: Codes & Instructions |
Hello Bertil,
Thank you for the tips and links.
I'll give it a try and reach out.
Stimmt, in den Links scheint auch das Problem zu sein, dass das SG des Kombi keine Werte annimmt. Just like me.
cu smith2
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
10-12-2003, 10:54 Subject: Audi Service Reset: Codes & Instructions |
Hello Smith2,
If you're having problems with the Autointern instructions, why don't you contact the knowledgeable forum there?
Translated on 28-08-2026, 5:12.
Profile PM WWW Garage |
