Golfmann Guest
19-11-2003, 20:05 Subject: Type designations? |
Hello everyone.
It might be a bit off-topic, but I constantly wonder which engine is installed in a VW based on its emblem.
Do they do things at VW the same way they're currently finding those letters, or is there a transparent system in place?
e.g., for the Golf and Passat. Are they different there?
Please write down whatever comes to mind.
PS: By the way, I'm referring to the red letters on the tailgate. (One red, two red, green, yellow, blue, duck-pattern  ).
PrivatBereich Guest
19-11-2003, 20:26 Subject: Type designations? |
It hasn't even been a month since we discussed this topic. The search function is your friend here.
The answer came from either Gremlin or Bertil, if I remember correctly.
Golfmann Guest
19-11-2003, 21:17 Subject: Type designations? |
I'm sorry, I didn't know about that back then.
For those who are as interested in this as I am, here's the link:
/viewtopic.php?t=3917&highlight=red+tdi
DocSnydor Guest
21-11-2003, 13:52 Subject: Type designations? |
What has not been clarified is:
What does the TDI mean on some T4s?
The TDI is only available on the Lupo 3L, right?
Joined: 04/12/2002 Posts: 18065 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
21-11-2003, 13:53 Subject: Type designations? |
You're worrying too much...
Profile PM WWW Garage |
Gremlin Guest
21-11-2003, 14:27 Subject: Type designations? |
However, what was not clarified:
he doesn't have a charge air cooler.
http://www.cheesebuerger.de/smilies/schilder/10.gif http://www.cheesebuerger.de/smilies/schilder/61.gif
CU Gremlin.
Golfmann Guest
21-11-2003, 20:02 Subject: Type designations? |
@ RainerK.
You should know who you're dealing with, or better yet, avoid them altogether.
Or from whom one is being scammed.
Julian Guest
21-11-2003, 22:31 Subject: Type designations? |
@ RainerK.
You are having problems.....
Gremlin Guest
22-11-2003, 1:46 Subject: Type designations? |
>>CLICK<<
Lichtschalter Guest
22-11-2003, 11:39 Subject: Type designations? |
@ Gremlin
Super
Best regards, light switch.
