Heavy Smoke: Causes and Prevention
schnubbi
Post11-12-2003, 8:39    Subject: Heavy Smoke: Causes and Prevention Quote
hello everyone,
In the cockpit, the preheating light is flashing. Additionally, there's a lot of smoke when you accelerate, and it also smells bad.
I checked for error codes using VAG-COM, and it indicated a faulty or disconnected needle lift solenoid. I followed the wiring as far as I could. I only saw one connector (next to the large round one). Are there perhaps any other connectors?
Is this smoking and bad smell related to that?
Here's the excerpt from VCDS (VAG-COM).
Vehicle Model: 7M - VW Sharan 1995.
Scan: 01, 02, 03, 08, 09, 15, 16, 17, 18, 36, 37, 45, 46, 55, 56.
Address 01 -------------------------------------------------------
Control unit: 028 906 021 ES
Component: G00SG 1448
Coding: 00002
Workshop code: WSC 12345.
1 error code found.
00542 - Needle feed mechanism.
30-00 - Disconnection/Short circuit after positive terminal.
Readiness: Not available.
Can we rule out any faults in the electrical connection?
Is the NHG actually defective?
Thank you very much in advance.
Best regards, Stephan.
Okay, it's actually a Ahu Sharan from the year 1997.
Translated on 22-08-2026, 11:37.
Marco
Post11-12-2003, 10:28    Subject: Heavy Smoke: Causes and Solutions Quote
Hello snubbi,
Before you replace the ignition coil (NHG), I would definitely check all cable connections for bare spots, short circuits, and breaks. Clean the connectors, etc. You can also try tapping the ignition coil with a screwdriver or similar object while the engine is running to see if it changes the engine's behavior. Otherwise, replace the ignition coil.
Translated on 22-08-2026, 11:40.
schnubbi
Post11-12-2003, 10:57    Subject: Heavy Smoke: Causes and Prevention Quote
hello marco,
Thank you for your reply.
Is there another type of connection besides the thick, round one?
It's quite cramped and difficult to make out details.
Is there a connection to the smoking? From what I've read, it should actually have a different cause.
I might also be wrong.
best regards, stephan
Translated on 22-08-2026, 11:42.
Marco
Post11-12-2003, 11:19    Subject: Heavy Smoke: Causes and Prevention Quote
In a simplified explanation, the NHG (likely referring to a specific engine component or system) controls the start of fuel injection and is therefore a potential cause of smoking. While it's possible that the smoking has another reason, I would first investigate the VAG-COM error messages to rule out this source as the problem.
Translated on 22-08-2026, 11:43.
schnubbi
Post11-12-2003, 11:22    Subject: Heavy Smoke: Causes and Prevention Quote
Okay.
I'll double-check everything again.
'Thank you.'
No new posts Engine Misfire: Smoking & Starting Problems Upload
No new posts Excessive smoke from 2.5 TDI V6 after cold start. Diesel Engine Technology
No new posts AVF TDI PD starkes Ansaugbrummen Diesel Engine Technology
No new posts TDI 2.0 16V BMN, severe idling issues Diesel Engine Technology
