Boost Pressure Behavior: Strange or Normal?
vespadriver
Post28-11-2002, 12:26    Subject: Boost Pressure Behavior: Strange or Normal? Quote
Hello everyone.
I have now finished my OBD adapter and logged some data yesterday, resulting in the following boost pressure curve:
http://home.snafu.de/sebastian.kausche/ladedruck.gif
The duty cycle decreased to a maximum of approximately 75%.
The engine is an ATJ and it's installed in a Passat manufactured in the year 2000.
gemessen wurde das bei Vollgas im 4. Okay.
Is this 'overshoot' behavior, which is quite significant, considered normal? And why does the setpoint go up to 2295? Shouldn't it be a maximum of 2150?
Here's the translation:
'Additional question: How does the control unit obtain the torque information? How reliable is this display?'
Sebastian.
Translated on 21-08-2026, 0:36.
Post28-11-2002, 14:10    Subject: Boost Pressure Behavior: Strange or Normal? Quote
Hello Sebastian,
"About 10% overboost is fine; I wouldn't worry about it. What would be interesting to know is the exact type of turbocharger used. Is your engine a 100 HP PD-TDI?"
Translated on 21-08-2026, 0:37.
vespadriver
Post28-11-2002, 14:53    Subject: Boost Pressure Behavior: Strange or Normal? Quote
Hi Rainer,
It's a Passat 3B Variant (also known as VTG), with a 115 hp PD ATJ engine producing 310 (or possibly 320) Nm of torque and a 5-speed manual transmission, featuring a VTG turbocharger.
Translated on 21-08-2026, 0:38.
vespadriver
Post29-11-2002, 14:15    Subject: Boost Pressure Behavior: Strange or Normal? Quote
I'm bumping this thread again, maybe someone else has something to say about it. icon_wink.gif
Sebastian.
Translated on 21-08-2026, 0:39.
PowerSound3L
Post27-11-2003, 21:15    Subject: Boost Pressure Behavior: Strange or Normal? Quote
hi,
I'm also bumping this topic again icon_wink.gif.
Here's the history of my Lupo 3L.
Isn't that a bit too exaggerated?
And doesn't the pressure come a little too late?
http://pics.m-eit.de/ladedruck.JPG
greetings
No new posts Boost Pressure vs. Throttle: Odd Behavior On-Board Diagnostics (OBD)
No new posts Boost Pressure Curve Diesel Engine Technology
No new posts Boost Pressure & Air Mass: Explained Diesel Engine Technology
No new posts Boost Pressure Curve Golf 4 1.9 TDI On-Board Diagnostics (OBD)
