Standheizung: Umbau von Zusatzheizung?
Johannes
Post25-06-2002, 20:12    Subject: Standheizung: Umbau von Zusatzheizung? Quote
Is it possible to convert the standard auxiliary heater into a stand heater?
I was thinking about adding an additional electric pump and control unit.
I have an A6 V6 TDI.
Best regards, Johannes.
Translated on 08-10-2026, 2:45.
schroederliese
Post25-06-2002, 21:17    Subject: Standheizung: Umbau von Zusatzheizung? Quote
I don't know how it works with Audi. Does the car have a fossil fuel auxiliary heater, meaning one powered by diesel? With Mercedes, you could upgrade it to a standing heater. It involved installing a few parts, possibly a circulation pump, a relay, a wiring harness, and a silencer for the heater unit. Auxiliary heaters don't have a silencer because the engine noise drowns out the heater noise. However, when the heater runs while the engine is off, it can be quite loud without a silencer. They didn't need a separate pump because one is already included for the auxiliary heater. You should check with Audi. With Mercedes, the upgrade kit cost around 500 German marks. Oh, and of course, you also need a timer to program it.
Translated on 08-10-2026, 2:46.
No new posts Standheizung Einbau: D5WSC mit Easystart R+ Installation Troubleshooting & Guides
No new posts Additional coolant heater for the TDI Technical Articles
No new posts Installation of an aftermarket seat heater Troubleshooting & Guides
No new posts TDI Auxiliary Heater - Stand Heater? Diesel Engine Technology
No new posts VP44 Pump Control Unit Remapping/Reflash Diesel Engine Technology
No new posts Auxiliary Heater for VW T5 On-Board Diagnostics (OBD)
No new posts Additional Heater for Sharan On-Board Diagnostics (OBD)
