Climate control channels 8 and 10 - Enter actual values directly
dcjf
Post11-12-2003, 11:56    Subject: Climate control channels 8 and 10 - Enter actual values directly Quote
Oh yes, and the problem I described earlier with the air control flap had nothing to do with what I suspected. The flap responsible for controlling the amount of outside air that passes through the heating radiator is called the temperature control flap. In channel 10c, you can query the setpoint value. The smaller the number, the more air is directed directly through the heating radiator. For me, the setting is at 20 (warm) and 248 (cold).
What was new to me, and what I hadn't seen in any documentation for climate control codes: If a channel is displayed with its actual value (for the temperature flap, this is channel 8c), then – and only then – can the actual value be changed using the +/- buttons for fan control. At this moment, the automatic control for this channel is obviously overridden.
Operating channel 8 is exactly the same as operating the temperature control on a conventional heating system. The only difference is that at the maximum setting... Do not close the heating valve when it is cold.
Or did you already know all of this?
Translated on 05-07-2026, 18:58.
PowerSound3L
Post11-12-2003, 16:21    Subject: Climate control channels 8 and 10 - Enter actual values directly Quote
hello,
No, I didn't know that.
Did you know that you can perform a basic setting on the Climatronic system by selecting channel 000 in the basic settings?
where does it determine the positions of the valves and relearn the end values?
greetings
Translated on 05-07-2026, 19:00.
dcjf
Post11-12-2003, 18:28    Subject: Climate control channels 8 and 10 - Enter actual values directly Quote
<Pardon>
Yes, I knew that it's possible to perform a basic adjustment where the flaps are moved from fully open to fully closed.
But: Does this also work (only) with the Climatronic control panel?
Translated on 05-07-2026, 19:01.
chris40
Post12-12-2003, 12:18    Subject: Climatronic default setting Quote
Well, how exactly does that work with the Climatronic control panel?
dcjf
Post12-12-2003, 17:37    Subject: Climate control channels 8 and 10 - Enter actual values directly Quote
Oops, I accidentally started a new thread. For those who want to know the background story:
Okay, I'm ready. Please provide the German text you want me to translate.
chris40
Post16-12-2003, 12:11    Subject: Climate control channels 8 and 10 - Enter actual values directly Quote
Okay, but the link unfortunately doesn't work.
Perhaps you could briefly describe the keyboard shortcut for the reset.
Best regards, Christian.
Translated on 05-07-2026, 19:02.
dcjf
Post16-12-2003, 12:20    Subject: Climate control channels 8 and 10 - Enter actual values directly Quote
Hello Christian,
As I said, I don't know if this will work with the control panel. However, for example, the temperature control flap can be manually adjusted using channel 10, while the recirculation air flap can be adjusted using channel 16.
Okay, this link should work now.
Translated on 05-07-2026, 19:03.
No new posts VAG-COM: Enter address 25 bit teA dress 17 On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Enter Piezo Injector :Pparameters using VCDS (3.0 TDI/BMK) Diesel Engine Technology
No new posts Injector Code Input (Common Rail) On-Board Diagnostics (OBD)
No new posts Climate Control Retrofit: Installation & Guide Diesel Engine Technology
