Error codes and their possible causes for MKB AKN (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post06-06-2002, 12:16    Subject: Error codes and their possible causes for MKB AKN Quote
Error Codes and Their Causes for the AKN Motor
{ERROR_CODE_1}: {CAUSE_1}
{ERROR_CODE_2}: {CAUSE_2}
{ERROR_CODE_3}: {CAUSE_3}
Error Code: 513
G-code for motor speed G28 impossible signal
Possible Causes:
G28 error
Distance between speed sensor/encoder wheel is too large
Metal shavings on the G28 or mounting socket.
no signal
Possible Causes
Circuit interruption or short circuit
Error Code: 519
Donor for suction tube pressure - G71 Short circuit to positive.
Possible Causes:
Short circuit after plus
G71 defect
Interruption/Short circuit
Possible Causes:
Circuit interruption or Short circuit to ground
G71 defect
Power supply
Possible Causes:
Error Code: 522
Sender for Coolant Temperature G62 Short Circuit to Ground
Possible Causes:
G62 failure
Head has short circuit to ground.
Interruption/Short circuit after plus
Possible Causes:
Circuit interruption or Lead short to positive
Error Code: 523
Giver for Intake Air Temperature G42 Short to Ground
Possible Causes:
G42 failure
Head shorted to ground
Possible Causes:
G42 failure
Circuit interruption or Short circuit after plus
Error Code: 532
Supply voltage: Implausible signal
Possible Causes:
Intermittent connection failure (loose contact)
Signal too small
Possible Causes:
Discharged Battery
Bad connection to the engine control unit
Possible Causes:
Relay for power supply, terminal 30 (J317) defective
Open entrance
Possible Causes:
Battery within 10 minutes after
Disconnecting the ignition
Error Code: 534
Sender for Oil Temperature G8 Short Circuit to Ground
Possible Causes:
G8 defect
Sender for Oil Temperature G8: Unrealistic Signal
Possible Causes:
G8 defect
Error Code: 539
Fuel Temperature Sensor G81 Short to Ground
Possible Causes:
G81 defect
Interruption/Short circuit after positive terminal
Possible Causes:
G81 defect
Error Code: 542
Donor for Needle Stroke G80 Interruption/Short Circuit to Plus
Possible Causes:
G80 failure
unplausible signal
Possible Causes:
G80 failure
Fuel line to cylinder 3. Cylinder not OK.
Fuel shortage
Air in the fuel system
Error Code: 550
Spritzbeginnregelung: Regelabweichung, Überschreitung oder Unterschreitung der Regelgrenze
Possible Causes:
Injector start valve (N108) defective)
Needle lift actuator (G80) defective
Fuel tank emptied.
Fuel supply not OK.
Fuel shortage
Funding start is okay.
Error Code: 553
Air Mass Meter G70 - Unrealistic Signal
Possible Causes:
G70 malfunction
Interruption/Short circuit to ground
Possible Causes:
Possible Causes:
G70 malfunction
Error Code: 560
Exhaust Gas Recirculation Regulatory Difference
Possible Causes:
Incorrect breathing
Exhaust gas recirculation (EGR) valve is faulty.
(Valve is stuck, diaphragm rod is not moving)
Hoses reversed, not attached, clogged or leaking
Error Code: 575
Suction tube pressure, control difference
Possible Causes:
Magnetic valve for pressure limiting (N75) is defective
Incorrect hose connections, not attached, leaking
Leak between turbocharger and engine (intake duct)
Turbocharger failure
Error Code: 625
Speed signal impossible signal
Possible Causes:
No signal from the sensor for the speedometer (G22)
Error Code: 626
Control lamp for pre-glow time K29 Interruption/Short circuit to ground
Possible Causes:
Light bulb is broken.
Possible Causes:
Error Code: 628
Job Title Monitoring: Unrealistic Signal
Possible Causes:
Fuel pump failure
Interruption/Short circuit to ground/ Circuit interruption
Possible Causes:
Possible Causes:
Interruption/Short circuit to positive/ Circuit interruption
Error Code: 668
Line voltage, terminal 30, implausible signal
Possible Causes:
Relays for Power Supply
Clamp 30 (J317) is defective
Relay is (occasionally)
Error Code: 671
Switch for GRA -E45 undefined switch state
Possible Causes:
E45 is broken.
Error Code: 741
Brake Pedal Monitoring - Unplausible Signal
Possible Causes:
Brake light switch (F) is faulty
Brake Pedal Switch (F47) - Defective
Error Code: 777
Gas pedal position sensor G79 - Unplausible signal
Possible Causes
G79 failure
Possible Causes
G79 failure
Power supply
Possible Causes
Error Code: 1028
Relay for Fans J323 Disconnect/Short to Ground
Possible Causes:
Circuit Interruption
Relay failure
Possible Causes
Error Code: 1044, 18008
Tax device incorrectly coded
Possible Causes:
Invalid ECU coding
Error Code: 1117
Overload signal for generator terminal DF - Unplausible signal
Possible Causes:
Generator malfunction
Voltage regulator failure
Error Code: 1126
Signal for motor speed Signal outside the tolerance
Possible Causes:
No signal
Fuel pump failure
Error Code: 1180
Motor/Air Conditioner Compressor - Disconnect Electrical Connection Short Circuit to Positive (+)
Possible Causes:
Short circuit in the pipeline
Error Code: 1259
Fuel pump relay J17, Open/Short to Ground
Possible Causes:
Fuel pump relay failure
Possible Causes:
Error Code: 1262
Magnet Valve - Charging Pressure Limiter - N75 - Open/Short to Ground
Possible Causes:
Magnet valve malfunction
Possible Causes:
Error Code: 1265
Ventil for Exhaust Gas Recirculation N18 Interruption/Short Circuit to Ground
Possible Causes:
Possible Causes:
Error Code: 1266
Text Relay for Filament J52 Open/Short to Ground
Possible Causes:
Relays for light bulbs are faulty.
Possible Causes:
Error Code: 1268
Set N146 Regulatory Difference
Possible Causes:
Fuel pump failure
lower threshold value
Possible Causes:
Counter mechanism malfunction
Metering system blocked due to dirt
upper limit value
Possible Causes:
Error Code: 1282
Switch valve for suction pipe valve N239, Disconnect/Short circuit to ground
Possible Causes:
Circuit interruption or short circuit to ground
Possible Causes:
Error Code: 1318
Injector pump control unit J399 defective
Possible Causes:
Fuel pump failure
no communication
Possible Causes:
Data signal to the fuel pump is faulty.
Error Code: 1375
Valves for Engine Storage Level 1 Disconnect/Short Circuit to Ground
Possible Causes:
Motor bearing (N144) or (N145) is defective
Possible Causes:
Error Code: 1376
No signal for the fuel pump speed signal.
Possible Causes:
Fuel pump not turning
Timing belt for fuel pump snapped.
defekt
Possible Causes:
Fuel pump failure
Error Code: 1440
Fuel Level Signal Interruption/Short Circuit after +
Possible Causes:
Short circuit to ground.
Possible Causes:
Error Code: 1441
Source: Fuel shortage G210 Interruption/Short circuit after positive terminal
Possible Causes:
G210 failure
Possible Causes:
G210 failure
unplausible signal
Possible Causes:
Fuel pump not working
Empty storage compartment
G210 failure
Error Code: 1442
Outages due to fuel shortage
Possible Causes:
Tank empty
Error Code: 1686
Steuergerät for radiator fan auxiliary J138: Interruption/Short circuit to ground
Possible Causes:
J138 defect
Ausgang does not switch on / Short circuit to positive.
Possible Causes:
Error Code: 17931
Crash-Signal from Airbag System: Unplausible Signal
Possible Causes:
Error in the data lines to the airbag control unit
17978
Engine control unit malfunction.
Possible Causes:
Attempt to start with unauthorized user
Key.
Attempt at manipulation
Short circuit of the
Communication Manager
Incorrect encoding
Errors in the system for
Immobilizer
Ignition control unit
defekt/missing
Engine control unit replaced and not working
Immobilizer adjusted.
Error Code: 18017
Crash shutdown initiated.
Possible Causes:
Airbag deployed.
Error Code: 65535
Taxation device J248 defective
Tschüss
Michael II
Ratings - Error codes and their possible causes for MKB AKN
No new posts Error codes and their possible causes for MKB AFN, AVG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and their possible causes for engine types 1Z... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and their possible causes for Mercedes-Benz AHD Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM Values: Meaning and Impact Diesel Engine Technology
No new posts mögliche Motorleistung 1Z bei vorgegebenem LD Diesel Engine Technology
No new posts Ursachen für Leistungsstreuungen? Diesel Engine Technology
No new posts Leerlaufruheregelung auf -2,4mg/H --> Ursachen ? Diesel Engine Technology
