.......my Ibiza TDI Sport with 96 KW will be delivered in mid-January
...I've already acquired a power box; it's the Plugmaster PD from Koch, so it's not some cheap eBay product that uses a brute-force method to measure fuel temperature, but rather it controls the injectors based on characteristic curves and in relation to the original parameters.
Okay, here's the translation:
'Now my question: I had a lowering kit from KW-Systems in my old Ibiza GT TDI (AFN) that could be switched on and off. Does it actually serve any purpose in terms of protecting the engine?'
.....even with the Koch tuning box, more diesel is only injected under full load, which means that if I drive tomorrow and don't accelerate hard or rev above 2000 RPM, the box isn't actually active, right? It's supposed to be active when the engine is warm and I give it gas, but if I don't want to 'tune' and just drive normally (without extreme acceleration or high RPM), the box also isn't active. So, it doesn't really make sense to have a switchable box since neither the injection pressure nor the boost pressure are being changed!
Sure, when I accelerate and the power box is active, the transmission, clutch, engine, etc., are subjected to the corresponding INCREASE in torque, but with the power box (165 hp / 365 Nm), it's still within a reasonable range.
What do the experts say about it?
Monchi.
