Auxiliary heating - glow plugs or similar.
Go to page: 1, 2  Next
OlliP
Post03-10-2002, 10:21    Subject: Auxiliary heating - glow plugs or similar. Quote
I have a SEAT Leon TDI with 110 horsepower, and I've noticed that...
even now, the box isn't getting warm - it will.
My first winter with it!!!!!
Now I've done some reading and realized that...
that my LEON has the auxiliary heater - glow plugs or whatever they're called.
'Auch immer' translates to 'whatever it may be' or 'no matter what.' 'Nicht besitzt' translates to 'does not own' or 'does not possess.' Do I need this for it to get warm?
Are these things no longer needed?
'That's what my dealer claims, at least!'
Do you have any tips?
Thank you.
Olli.
Post03-10-2002, 12:26    Subject: Re: Auxiliary heating - glow plugs or similar. Quote
OlliP wrote:
Now I have done some reading and realized
"auch immer" means "whatever".
Hi Olli,
That surprises me a bit... AFAIK, only the first generation of TDI engines lacked glow plugs, but the Leon seems too new for that. icon_question.gif
Have you carefully checked in the engine compartment --> specifically, the hot water hose running from the engine towards the heater?
Reading the operating manual is useless because it doesn't contain any information about it (at best, it might tell you where the fuse is located), since the whole process is fully automatic.
Do I need them for it to get warm?
!!!That's what my dealer claims, at least!!!
With that, it will only get
slightly warmer.
Of course, it's also possible to do without it, so your dealer is right again.
Post03-10-2002, 12:43    Subject: Auxiliary heating - glow plugs or similar. Quote
Hi Olli,
If your current heating system is not providing enough heat, I recommend installing a separate heater or an electric auxiliary heater (e.g., CALIX, see Rainer's homepage). You can find more information at [url][/url], then on the English version. Go to the "Flag" section and then to "Products" -> "Engine Preheaters". Enter your car details.http://www.calix.se{MARKER}
mi15hu
Post09-12-2003, 16:31    Subject: Engine oil preheater Quote
I found a motorcycle oil warmer and would like to know if anyone has experience with it. Link: [link]
http://nerace.com/miva/merchant.mv?Screen=PROD&Store_Code=NRCP&Product_Code=23980&Category_Code=MOR-O
or an oil pan heater pad?
http://nerace.com/miva/merchant.mv?Screen=PROD&Store_Code=NRCP&Product_Code=23995&Category_Code=MOR-O
olbetec
Post09-12-2003, 18:12    Subject: Info... Quote
Just for information: My 1.9 PD ATD engine also doesn't have glow plugs. Is the PTC (Positive Temperature Coefficient) heater element located directly in front of the heater core in the Fabia?
According to the parts catalog, whether this auxiliary heater is installed in the TDI engine depends on the equipment level. It is controlled using the same relays for high and low heating power (J359/J360).
Perhaps your solution is also unconventional...
Stay cheerful.
OlBe.
Fabia I TDI, EZ06/01 (1,9/74kW, ATD)
Octavia II TDI DSG EZ11/06 (2,0/103kW, BMM)
Avatar-Jan6K
Post09-12-2003, 19:07    Subject: Auxiliary heating - glow plugs or similar. Quote
Hi Olbe,
Ah... so that would be another option.
Hmm... I don't have glow plug heating in my Ibiza either, but I can't really complain about how quickly it warms up.
On the other hand, nothing clicks when I activate the relevant relays via diagnostics, and, more importantly, the light doesn't get dimmer, which is what should happen if the heating element is working.
Or would that require the ventilation system to be running during the test?
Jan.
1Z5 CFHF / AHB H4D
D.
I just read Jan6K's article about oil temperature in winter, and I was also surprised to see that, like Jan6K, my Seat Ibiza also doesn't have glow plugs.
It seems to be a Spanish brand, Seat.
Best regards, D.
D.
Post09-12-2003, 19:08    Subject: Auxiliary heating - glow plugs or similar. Quote
Well, it seems Jan6K answered at the same time.
Best regards from Braunschweig, D.
Post09-12-2003, 19:14    Subject: Re: Engine oil preheater Quote
mi15hu wrote:
I found a motorcycle oil pre-heater, and I would like to know if anyone has experience with it. Link:
Great, a full 360 watts... that really makes a difference. A parking heater has several kilowatts, while my Calix has 650 watts.
If you read the technical article about CALIX, you'll quickly see that it takes quite a long time to see any results with 650W.
Post09-12-2003, 21:11    Subject: Auxiliary heating - glow plugs or similar. Quote
My Dutch-market Golf also doesn't have a GSH (Gasoline Particulate System), it's a PD 130PS ASZ model.
Avatar-Jan6K
Post09-12-2003, 21:28    Subject: Auxiliary heating - glow plugs or similar. Quote
Actually, it's quite logical. Due to the different tax situation, VAG earns less on the cars sold in the Netherlands than it does in Germany, which makes the pressure to save even more pronounced. So, what's closer than simply removing things that don't necessarily need to be there?
Furthermore, the Netherlands is a relatively flat country, and there are few mountains where it might be colder, so the need for heating is also lower.
Even with the Ibiza 6K, the Signo DE and Signo NL models differ in some minor details (aside from major things like airbags or engine options). For example, the Signo in the German market has dampened grab handles, while the one in the Netherlands does not. In Germany, there's a 12V socket in the trunk, but in the Netherlands, there isn't.
The part that Olbetec mentioned is interesting. It might be much easier to retrofit than a glow plug heater. Are there any more details about that?
Jan.
1Z5 CFHF / AHB H4D
mi15hu
Post09-12-2003, 22:04    Subject: Pre-heater! Quote
icon_eek.gif To Bertil! What do you think about adding a few more watts?
http://www.etipinc.com/universal_app.asp{MARKER}
Post09-12-2003, 22:56    Subject: Auxiliary heating - glow plugs or similar. Quote
Hi.
Well, then! With 455/900 watts, you should be able to achieve something...
It would probably be better to heat the water, as it warms the entire block and head more evenly. The engine oil is heated up along with the water using the water-to-oil heat exchanger.
Are these parts also available for 220V?
What does a heater like that cost?
mi15hu
Post10-12-2003, 7:59    Subject: Sorry Quote
Sorry, I just wanted to show my colleagues how things work!
mi15hu
Post10-12-2003, 8:08    Subject: Auxiliary heating - glow plugs or similar. Quote
icon_smile.gif Copy of the email I received!
Thank you for your interest in our line of high-watt density universal [products/devices/etc.].
Engine preheaters.
transmissions, hydraulic reservoirs, gearboxes, hydrostatics, etc. These...
all comply with UL (Underwriters Laboratories) Approval #E95403 and are sized.
according to the oil pan's capacity.
Here is the price, per unit, for the 110VAC LWD (Low Watt Density) product. It.
comes
with pigtail electrical leads only (no insulation pad, cord, plug, or RTV).
adhesive).
#10LWD (50 watt) $40.82; 2' x 5', for 1-3 quart engine oil pan.
The following high-watt density preheaters come with a 7-foot cord and...
grounded (3-wire) plug, insulation pad.
and RTV adhesive. With the insulation pad in position, the heater and pad are...
.050 inch thick.
#125W (92 watts) $46; 3' diameter, for 2-4 quart engine oil pan.
#300W (234 watts) $57; 4' x 4.5' for 4 to 10 quart engine oil pan.
#600W (455 watt) $71; 5' x 7' for 11-22 quart engine oil pan.
#1100W (900 watt) $83; 6.5' x 10.75' for 22-48 quart engine oil pan.
Here are the individual prices for the 220VAC HWD (High Watt Density) models. These.
come with all of them.
same features as the 110VAC models, except that there is no plug on the cord.
Engine oil pan sizes and watt ratings are the same as those for the 110VAC models.
125W: $54; 300W: $70; 600W: $86; 1100W: $100
If one preheater is not sufficient for your needs, a second preheater can be...
added. If the dimensions are correct for your oil pan capacity, then...
too large, two smaller.
'ones' can be used instead. If the bottom of the oil pan suffers a lot of damage,
such as in snow plow service or farming applications, mount the heater to...
the side of the pan being...
Make sure to keep the heater below the level of the oil.
We have added two new heaters (same construction: silicone/fiberglass).
KB-7515 Battery Heater Pad, 75 watts, 19' x 10.5'. Place the battery on top.
and plugs into 110VAC. Includes a 6-foot, three-conductor cord and plug. $142.80
DRUMHEATER for 55-gallon steel drums, 1500 watts, 110VAC. 4.5 inches wide with...
adjustable thermostat, 6-foot three-conductor cord with plug. Patent pending.
Hook and loop closure. Flexible, can be rolled up for storage. $275.00
Inquire about our low-wattage density preheaters.
Shipping and handling charges for United Parcel Service will be added to...
your order within the continental U.S. as follows: 1 to 3 Preheaters @
$9.00; 4-6 preheaters @ $11.00. Please provide the text you would like me to translate from German to English.
Shipping instructions preference. Special order preheaters are priced upon request.
on a per-order basis.
Prices and specifications are subject to change without prior notice, and prices...
are subject to all applicable taxes and are quoted F.O.B. the factory or.
North Aurora, IL, USA.
Availability and delivery are subject to wars, strikes, and other unforeseen events.
beyond our control, including the availability of limited-supply offers that are.
Subject to prior sale. Payment is to be made in U.S. funds only. Checks are to be...
Payment must be made through/to a U.S. bank. Payment terms are prepayment or cash on delivery (C.O.D.). MasterCard and...
Visas are accepted.
E TIP is a small business owned by a veteran. Call us at (630) 966-8992 or fax.
Contact us at (630) 801-9569; visit us at www.etipinc.com or email us at [email protected]
[email protected]
HB.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post10-12-2003, 17:03    Subject: Auxiliary heating - glow plugs or similar. Quote
Hello!
Here in the Lupo3l forum, you can take a look at a PTC auxiliary heater.
[url][/url]
Kamil F. even describes the power consumption or wattage.
pretzelhttp://www.lupo3lclub.de/forum/viewtopic.php?t=935&postdays=0&postorder=asc&highlight=ptc%20heizelement&start=15{MARKER}
No new posts 1.9 TDI PD Glow Plugs: Replacement & Info Diesel Engine Technology
No new posts Spark Plug Test - 11V? Diesel Engine Technology
