Heated Side Mirrors
Schneemann
Avatar-Schneemann
Post19-12-2003, 20:08    Subject: Heated Side Mirrors Quote
Good evening, everyone,
I have a question about the heated side mirrors on the G3.
Does anyone know the internal resistance? On the left, I have 112 Ohms, and on the right, I have 356 Ohms. The voltage is also quite high.
Sometimes one person goes, sometimes none, and sometimes even both. But not really satisfying.
Are these things actually hot, or just a little warm?
Wishing you a happy holiday season and a safe and accident-free start to the year 2004...
Gruß Schneemann
Golf Plus Highline Bj. 09/2010 CFHC. eFH, eSP, Climatronic, PDC, AHK, ABS, ESP, GRA, MFA, LMAA, FDH, BSE, Brenderup Kippi 200 und ne Traumfrau auf dem Beifahrersitz.
Dan.jel
Post19-12-2003, 20:28    Subject: Heated Side Mirrors Quote
I don't know the internal resistance, but they should definitely be warm enough to handle.
I am testing the function by blowing against it in cold weather.
PrivatBereich
Post20-12-2003, 14:26    Subject: Heated Side Mirrors Quote
I don't know the exact required resistance. However, according to P=U*I or P=U*U/R and a voltage of approximately U=12V, you would have a power of P=12*12/112= approximately one watt. This is definitely too low. In my opinion, the power should be around 10 watts. Therefore, the resistance R should not be greater than 14 ohms. Anything above 30 Ohms is definitely insufficient for me.
Greetings
Private Area
Eum76
Post20-12-2003, 18:16    Subject: Heated Side Mirrors Quote
Hello!
The tinted side mirrors are designed such that they are on the back with
Two conductor paths are present, which are not directly connected to each other.
The electrical heating element creates a conductive layer that extends over these two lead paths.
has been assigned. However, this layer seems to peel away over the years (was observed in)
(at least for me), which is why your Ohm values are also much too high and vary so much.
If one has sufficient skill and dexterity, one can repair them:
I have completely removed the sealant layer from my mirrors. To do this, you need to
Carefully remove the plastic backing (best done with label remover), and connect the ends of the two conductive tracks together, as these also have an electrical resistance and are distributed throughout the entire mirror. Then, one sticks it on.
reinstall the plastic holder (I used 2K adhesive).
The Spiegel now has approximately 14W.
Slightly less power output than the original (around 20W), but still heats wonderfully.
P.S.: It might sound a bit like 'McGyver' all of a sudden, but I do enjoy tinkering;-)
Olli
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post20-12-2003, 19:47    Subject: Heated Side Mirrors Quote
Hi!
@Eum76:
So, there isn't a "conductive layer" in the mirror. The heating resistance is actually the relatively poorly conductive trace itself, which runs along the entire back of the mirror glass... It's just glue, but it's really, really difficult to remove...
Dirk
Schneemann
Avatar-Schneemann
Post20-12-2003, 21:34    Subject: Heated Side Mirrors Quote
Thank you everyone, you've been a great help. While I am an electrician, I find myself more interested in switchgear and robots than in mirror heaters.
I guess I'll have to make time for the craft activity. I now have plenty of time to think about the holidays.
Gruß Schneemann
Eum76
Post21-12-2003, 13:53    Subject: Heated Side Mirrors Quote
@brezelmann:
Hello!
This is really true! I was also wondering what it was all about.
If you look closely, you should notice that the ladder track
Actually, there are two conductor paths somewhere on the reflective surface, ENDS.
The coating must be conductive.
Certainly, I can't explain it any other way, that the resistance
The higher it went, the more (rest)layers I washed off with acetone.
Maybe the heated mirrors were also changed due to the manufacturing year.
but in my G3, manufactured in '97, they are set up like this.
Olli
brezelmann01
Post21-12-2003, 13:59    Subject: Heated Side Mirrors Quote
might be. My experiences were based on a right-hand drive Golf 4 with a 6.99 build date.
No new posts Passat 2000: Heated Mirror Not Working? (Troubleshooting) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Beheizter Außenspiegel mal anders! Transmission, Chassis, Body & Interior
No new posts Exterior mirror glass adhesive Transmission, Chassis, Body & Interior
No new posts Automatic folding exterior mirrors - Installation assista... Diesel Engine Technology
No new posts Anklappbare Außenspiegel beim Touran nachrüsten Transmission, Chassis, Body & Interior
