Are all reading spools the same?
T2-TDI
Post01-01-2004, 14:00    Subject: Are all reading spools the same? Quote
Hello, I have the following problem. In my T2 bus, I have a 1Z ignition module from an Audi 80. The pickup coil is permanently connected to the ignition switch of the Audi. However, I only realized this when I tried to remove it with a screwdriver and install it in my bus.
Now, bring me the control unit; the reading coil is defective.
Can I actually also buy a reading coil from a Golf 3? As far as I know, it's separate, or do I need the complete immobilizer control unit, reading coil, and transponder?
I need a very quick answer; I have to go buy one tomorrow because 1 second of engine running is not enough for me to get to work.
Greetings, Andi.
Translated on 21-07-2026, 7:25.
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Interesting for all Passat owners from 1996 onwards. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Central Locking: How to Program (2002+) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Catalunya: Are They Painted? Transmission, Chassis, Body & Interior
No new posts Are the air mass sensors wear and tear parts? Diesel Engine Technology
No new posts Compatible Tank Caps: 6N0 vs 1H0? Diesel Engine Technology
No new posts Are the plastic air guides in front of the air filter imp... Diesel Engine Technology
