Error codes and their possible causes for MKB ASV, ALH, AGR (Solution)
Michael II
Post07-06-2002, 12:15    Subject: Error codes and their possible causes for MKB ASV, ALH, AGR Quote
Error codes and their causes for the ASV, AGR, and ALH engines
Error Code: 668
Line voltage, terminal 30, implausible signal
Possible Causes:
Relays for Power Supply
Clamp 30 (J317) is defective
Relay is (occasionally)
Signal too small
Possible Causes:
Error Code: 671
Switch for GRA -E45 undefined switch state
Possible Causes:
E45 is broken.
Circuit interruption or Short circuit
Error Code: 741
Brake Pedal Monitoring - Unplausible Signal
Possible Causes:
Brake light switch (F) is faulty
Brake Pedal Switch (F47) - Defective
Error Code: 1044
Tax device incorrectly coded
Possible Causes:
Invalid ECU coding
Error Code: 1117
Generator terminal DF - Unplausible signal
Possible Causes:
Generator malfunction
Voltage regulator failure
Error Code: 1193
Relay for small heating power - J359 Short circuit to positive supply
Possible Causes:
Short circuit after plus
defekt
1194
Relays for high heating power - J360 Short circuit to positive supply
Possible Causes:
Relays for high heating power - J360 defective
Error Code: 1283
Motor for Intake Valve V157 Interruption/Short Circuit to Ground
Possible Causes:
Engine for intake valve defective
Possible Causes:
defekt
Possible Causes:
Faulty fuel shut-off valve
Error Code: 16485
Air Mass Meter G70 - Unrealistic Signal
Possible Causes:
G70 malfunction
Circuit interruption, Short circuit to ground
Error Code: 16500
Sender for Coolant Temperature G62 - Unplausible Signal
Possible Causes
G62 failure
Error Code: 16705
G-code for motor speed G28 impossible signal
Possible Causes:
G28 error
Distance between speed sensor/encoder wheel is too large
Metal shavings at the G28 or. Base plate
G80 malfunction - Try disconnecting it temporarily!
Error Code: 16706
no signal
Possible Causes
G28 error
Error Code: 16885
Vehicle Speed Signal - Unplausible Signal
Possible Causes
No signal from the speedometer sensor (G22)
Error Code: 16955
Brake light switch - Unplausible signal
Possible Causes
Error Code: 16989
Tax component J248 defective
Error Code: 17552
Airflow sensor G70 - Open circuit/Short to ground
Possible Causes:
G70 malfunction
Circuit interruption or Short circuit to ground
Error Code: 17553
Airflow sensor G70 Short circuit to positive (+)
Possible Causes:
Short circuit after + G70 failure
Circuit interruption or Short circuit after plus
Error Code: 17554
Air Mass Meter G70 Power Supply Voltage
Possible Causes:
Operating voltage too high/too low
Error Code: 17563
Donor for suction tube pressure G71 Short circuit to positive
Possible Causes:
G71 defect
Error Code: 17564
Donor for suction tube pressure G71 Interruption/Short circuit to ground
Possible Causes:
G71 defect
Error Code: 17565
Power supply for suction tube pressure G71
Possible Causes:
G71 defect
Error Code: 17568
Donor for Suction Pipe Temperature G72 Short Circuit to Ground
Possible Causes:
G72 failure
Head shorted to ground
Error Code: 17569
Donor for Suction Pipe Temperature G72 Interruption/Short Circuit to Positive
Possible Causes:
G72 failure
Error Code: 17570
Fuel Temperature Sensor G81 Short to Ground
Possible Causes:
G81 defect
Error Code: 17571
Donor for Fuel Temperature G81 Open/Short to Plus
Possible Causes:
G81 defect
Lead short to positive
Error Code: 17653
Faulty Needle Stroke G80 Short Circuit to Ground
Possible Causes:
G80 failure
Error Code: 17654
Signal for Needle Stroke G80 - Unrealistic
Possible Causes:
G80 failure
Fuel line to the fuel injector with
Needle travel not OK.
Fuel shortage
Air in the fuel system
Error Code: 17655
Donor for Needle Stroke G80 Interruption/Short Circuit to Plus
Possible Causes:
G80 failure
Error Code: 17656
Spritzbeginnregelung Regeldifferenz
Possible Causes:
Injector start valve (N108))
defekt
Needle lift actuator (G80) defective
Fuel tank emptied.
Fuel supply not OK.
Fuel shortage
Funding start is okay.
Error Code: 17659
Injector Start Valve N108 Short Circuit to Plus
Possible Causes:
Error Code: 17660
Injector Start Valve N108 - Interruption/Short Circuit to Ground
Possible Causes:
Injector start valve defective
Error Code: 17663
Coolant Temperature Sensor G62 Short to Ground
Possible Causes:
G62 failure
Error Code: 17664
Donor for Coolant Temperature G62 Interruption/Short Circuit after Plus
Possible Causes:
G62 failure
Circuit interruption or Lead short to positive
Error Code: 17762
Electric control for the gear shifting mechanism G149. Fault in the electrical circuit
Possible Causes:
Electrical fault in the fuel pump circuit, defective.
Error Code: 17795
Control unit malfunction
Possible Causes:
Internal control unit malfunction
Error Code: 17810
Exhaust Gas Recirculation Valve N18 Short Circuit to Positive (+
Possible Causes:
Error Code: 17849
Exhaust Gas Recirculation Valve N18 - Interruption/Short Circuit to Ground
Possible Causes:
Exhaust gas recirculation (EGR) valve is faulty.
Error Code: 17911
Possible Causes:
Error Code: 17946
Fuel Shut-Off Valve N109 - Interruption/Short to Ground
Possible Causes:
N109 defective
Error Code: 17948
Vehicle Speed Signal: Signal too large
Possible Causes:
Driving speed greater than 260 km/h
Control panel failure
Error Code: 17954
Magnet Valve, Charging Pressure Limiter, N75, Short Circuit to Positive (+)
Possible Causes:
Error Code: 17957
Magnet Valve, Charging Pressure Limiting, N75, Open/Short to Ground
Possible Causes:
Magnet valve malfunction
Error Code: 17964
Loading pressure control, lower limit reached
Possible Causes:
Magnetic valve for pressure regulation (N75) is faulty, hose connections leaking.
Turbocharger failure
Leak between turbocharger and engine (intake duct)
Error Code: 17965
Loading pressure control: Control limit exceeded
Possible Causes:
Incorrect hose connections, not attached, leaking
Further assistance through searching for *575 and Regeldifferenz Saugrohrdruck.
Error Code: 17969
Quantity Identifier N146 Regulatory Difference
Possible Causes:
Fuel pump failure
Error Code: 17970
Quantity: N146, Upper Limit
Possible Causes:
Quantity Counter (N146) defective/blocked
Upper limit reached.
Error Code: 17971
Lower limit for quantity N146
Possible Causes:
lower threshold value reached
Error Code: 17977
Switch for GRA E45 - Unplausible Signal
Possible Causes:
E45 is broken.
Error Code: 17978
Engine control unit malfunction.
Possible Causes:
Attempt to start with unauthorized user
Key.
Attempt at manipulation
Short circuit of the
Communication Manager
Incorrect encoding
Errors in the system for
Immobilizer
Ignition control unit
defekt/missing
Engine control unit replaced and not working
Immobilizer adjusted.
Error Code: 18008
Voltage Class 15, voltage too low
Possible Causes:
Voltage at ignition (terminal 15) is not present
Error Code: 18009
Relay for Voltage-Supply Terminal 30 J317
Possible Causes:
Relay for power supply, terminal 30 (J317) defective
Error Code: 18020
Incorrectly coded engine control unit
Possible Causes:
Invalid ECU coding
Error Code: 18026
Relays for incandescent bulbs J52 Short circuit to positive.
Possible Causes:
Main supply short circuit after J52
18027
Relays for incandescent bulbs J52, open/short to ground
Possible Causes:
J52 defect
Error Code: 18034
Data Bus Motor Missing Message from Gearbox Control Unit
Possible Causes:
Data line errors to the transmission control unit (TCU)
Error Code: 18039
Gas pedal position sensor G79 signal too high
Possible Causes:
G79 failure
Error Code: 18040
Gas Pedal Position Sensor G79 Supply Voltage
Possible Causes:
Error Code: 18044
Data Bus, Motor, Missing Message from Airbag ECU
Possible Causes:
Error in the data lines to the airbag control unit
Error Code: 18047
Provide 1/2 for Gas Pedal Position G79+G185 - Unplausible Signal
Possible Causes:
G79 failure
18048
Engine Control Unit J248 faulty
Possible Causes:
Error Code: 18062
Please read the fault codes from the combined instrument.
Possible Causes
Oil level/temperature sensor malfunction
Error Code: 18065
Air Conditioner Input/Output Short to Positive
Possible Causes:
Short circuit in the pipeline
Error Code: 19458
Kick-Down-Switch F8: Implausible signal
Possible Causes:
G79 failure
Error Code: 19459
Relay for small heating J359 Short circuit to positive supply
Possible Causes:
Relay for small heating J359 is defective
Error Code: 19461
Relays for high heating power J360 Short circuit to positive supply
Possible Causes:
Relay for small heating J360 is defective
Error Code: 19560
Switch valve for suction valve N239 Short circuit to positive (+)
Possible Causes:
Error Code: 19561
Switch valve for suction pipe valve N239, Disconnect/Short circuit to ground
Possible Causes:
Shift valve for suction valve defective
Error Code: 65535
Bitte gib den Text, den du übersetzt haben möchtest. Engine Control Unit J248 faulty
Tschüss
Michael II
Ratings - Error codes and their possible causes for MKB ASV, ALH, AGR
No new posts Error codes and their possible causes for MKB AFN, AVG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and their possible causes for engine types 1Z... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and their possible causes for MKB AKN Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM Values: Meaning and Impact Diesel Engine Technology
No new posts mögliche Motorleistung 1Z bei vorgegebenem LD Diesel Engine Technology
No new posts Ursachen für Leistungsstreuungen? Diesel Engine Technology
No new posts Idling Oxygen Sensor: Causes of -2.4mg/H Reading Diesel Engine Technology
