AJM: How many staples?
GerTDi
Post26-12-2003, 19:37    Subject: AJM: How many staples? Quote
Short question(s): How many icon_redface.gif staples are used to attach the upper timing belt cover on the AJM engine (in the Bora)? Is it only the two that you can immediately see/feel, or is there another one (according to the 'Do it yourself' book)? It seems like there are only two, but I'm now unsure... icon_confused.gif
Does the cover also need to click into place at the bottom/back (towards the splash guard), or is it correctly positioned if it sits properly in the guides at the top and front? The 'touch test' says everything is okay... In other words, is it possible to break something there? If so, I'm particularly prone to doing that icon_rolleyes.gif.
I wanted to take a quick look at the ZR today, but there isn't really much space because of the air ducting }.
Translated on 16-10-2026, 12:57.
Dan.jel
Post27-12-2003, 11:08    Subject: AJM: How many staples? Quote
Just remove the hoses from the intercooler, and then you should be able to see it clearly.
I would like to check my AJM myself, but it is already thick and securely packaged... icon_rolleyes.gif
Translated on 16-10-2026, 12:58.
No new posts TDI Engines: How Many 110 HP Models? Diesel Engine Technology
No new posts TDI: How many idler pulleys? Diesel Engine Technology
