Wankel Engine: How it Works & Benefits
Go to page: 1, 2  Next
Marco
Post22-01-2004, 11:34    Subject: Wankel Engine: How it Works & Benefits Quote
Hello everyone,
Since Mazda brought back the old Wankel engine with the RX8.
- What do you think about the Wankel engine, also known as the rotary engine?
- What about the durability?
- Would a diesel-powered KKM (presumably a type of machine) with turbocharging be feasible?
A technique that I find very interesting.
http://www.der-wankelmotor.de/Wankelmotor/wankelmotor.html
Translated on 12-10-2026, 22:01.
joergs
Post22-01-2004, 11:59    Subject: Wankel Engine: How it Works & Benefits Quote
As a former (and sometimes still) model builder, I once had a Wankel engine in a delta airplane. It was quite quiet, and it also had very little vibration. The RPMs were 'a bit' lower than those of a Webra or Cox engine back then. But what bothered me a little was the sealing problem! The compression decreased after not too much running time, until it became so low that the little engine was difficult or impossible to start. Overall, in my opinion, it's a good project, but is it suitable for everyday use?
Translated on 12-10-2026, 22:03.
Post22-01-2004, 12:05    Subject: Wankel Engine: Information and Discussion Quote
Marco wrote:
- Would a diesel-powered combined heat and power (CHP) system with turbocharging be feasible?
... Why not...?
http://www.der-wankelmotor.de/Motoren/Yanmar-Diesel/yanmar-diesel.html
The problem with Wankel engines has always been the seals. This should be easier to manage with the materials used today, but it remains to be seen how it will perform with the high pressures found in diesel engines.
It's probably going to be difficult to achieve in the long run.
@joergs
I used to dream of having a Wankel engine on a model airplane, but I only ever ended up with a 0.8 Cox engine on my glider. I've been flying again for a year now, but now I'm an "eco" flyer using electric motors icon_lol.gif.
Translated on 12-10-2026, 22:04.
joergs
Post22-01-2004, 12:29    Subject: Wankel Engine: How it Works & Benefits Quote
@bertil
As someone from East Germany, you could only dream of things like that. However, I had a supportive family who encouraged my hobby. I had a 2.8-meter glider with a 1.5cc Webra engine and a tuned pipe. It would run at 15,000 RPM. The Cox was also a 0.8cc engine on a small glider. The Delta was a fun project from my father. It was a lot of fun. Unfortunately, I no longer have the time or motivation for it, as the landing fees can be quite expensive, and ultimately, I lacked practice. In my workshop, I still have a highly accurate replica of an ASK-16. It's an amazing model and a great 'mother.'
I bought and assembled a 1:8 4WD car kit 3 years ago. When I'm really in the mood, I take it out, and then it's off to the track! If there wasn't so much snow at home, I would be at the track this weekend! icon_sad.gif
Translated on 12-10-2026, 22:06.
Marco
Post22-01-2004, 12:31    Subject: Wankel Engine: How it Works & Benefits Quote
@Bertil,
I must have overlooked that.
Translated on 12-10-2026, 22:08.
donalexo
Post22-01-2004, 12:33    Subject: Wankel Engine: How it Works & Benefits Quote
Hello everyone!
I believe building a diesel-powered Wankel engine is extremely difficult, if not impossible, because the sickle-shaped combustion chamber has an extremely large surface area (leading to a poor thermal efficiency) and is therefore very complex.
Try achieving a uniform fuel distribution in such an unfavorable combustion chamber geometry!
For gasoline engines, this is simpler because the air-fuel mixture is already being drawn in.
The location and design of the injector also present a challenge.
While a combustion chamber recess in the piston is conceivable even for a Wankel engine, the injector cannot protrude into it, as it would otherwise be sheared off by the next corner of the piston.
Perhaps a pre-combustion chamber/swirl chamber variant could be considered, where the combustion chamber is integrated into the engine housing. At the moment, this is the only option I can realistically envision.
What do you think about it?
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 12-10-2026, 22:09.
joergs
Post22-01-2004, 12:41    Subject: Wankel Engine: How it Works & Benefits Quote
From my perspective, Donalexo is somewhat right.
In addition to the problems mentioned, there's also the sealing issue. Even though the technologies and materials are much more advanced now than they were 15 years ago, I still think there might be a greater wear problem due to the compression and combustion pressures.
Translated on 12-10-2026, 22:11.
Marco
Post22-01-2004, 12:45    Subject: Wankel Engine: How it Works & Benefits Quote
A potential issue related to the engine's speed could be the slower combustion rates of diesel fuel.
christians
Post22-01-2004, 12:51    Subject: Wankel Engine: How it Works & Benefits Quote
Please share your concerns.
@ Jörg: Was that the Delta model that Graupner released in 1978 (or thereabouts)?
As a student and for some time afterward, I was also a model airplane enthusiast, using engines like the Enya 1.6, HB 3.2, Suppentiger 6.5, OS 6.5 four-stroke, and various Mabuchi 550 motors.
The matter then faded away due to time constraints or other interests.
Gruß Christian
Translated on 12-10-2026, 22:12.
Marco
Post22-01-2004, 12:56    Subject: Wankel Engine: How it Works & Benefits Quote
Hello everyone!
Alex
Hi Alex,
To compensate for the unfavorably shaped combustion chamber, one could use multiple injectors. With a precisely timed injection start, I believe a relatively uniform combustion process can be achieved. However, a version with a swirl chamber would be preferable.
Translated on 12-10-2026, 22:14.
Post22-01-2004, 13:05    Subject: Wankel Engine: How it Works & Benefits Quote
Marco wrote:
@Bertil,
I probably overlooked that somehow.
"Okay, let's talk about it. I think it's good to sometimes focus on positive things and not just dwell on existing problems."
By the way, so far, only "professional mechanics" seem to want to participate in the discussion. icon_biggrin.gif
Translated on 12-10-2026, 22:16.
joergs
Post22-01-2004, 13:08    Subject: Wankel Engine: How it Works & Benefits Quote
@christians
No, the Delta was a custom-built project. My dad largely designed and built it himself.
I also remember the Enya 1.6 (I think it was 1.67ccm). I bought one of those back in the day from a Czech supplier. It was a lovely little engine with L-piston design. The OS-Max engines were also great, but not as suitable for the F3BMS class back then. In that class, it was all about achieving high RPMs to give the glider as much altitude as possible to meet the required flight time! By the way, my neighbor is Ulrich Meyer, who is at least known in the former East Germany, and who is known for, among other things, the Aircobra. Today, he professionally manufactures GFK (glass fiber reinforced plastic) wings and fuselages for gliders with a wingspan of 3.5m to 8m! I can only say that those are awesome projects!
Translated on 12-10-2026, 22:17.
donalexo
Post22-01-2004, 20:11    Subject: Wankel Engine: How it Works & Benefits Quote
@MarcoViewing profile: Marco:
By precisely timing the injection start, I believe a relatively uniform combustion process can be achieved. icon_biggrin.gif
I believe that it's not possible to implement direct injection with a Wankel engine because you can't create the swirl necessary for proper air-fuel mixing in the complex, very tight, and sickle-shaped combustion chamber.
With an external vortex chamber, however, it works }.
Due to the large surface area of the combustion chamber, the compression ratio would also have to be significantly increased in order to reach the ignition temperature.
Even with (the prohibitively expensive) injection system using multiple distributed injectors, the design of the combustion chamber remains a question. I must point out that the high compression ratio would result in an extremely shallow flame front, where the fuel jet would immediately come into contact with the piston or cylinder head.
A combustion process similar to the "Mittenkugel M-process" does not work in the Wankel engine either, because in this engine, the swirl of the air plays an even more important role than in a TDI engine.
I continue to maintain my position that, if a diesel engine based on the Wankel principle can be built at all, it should be a swirl/pre-chamber diesel.
Alex.
Translated on 12-10-2026, 22:19.
Gremlin
Post22-01-2004, 20:44    Subject: Wankel Engine: How it Works & Benefits Quote
http://www.wankel-ag.de/locr.html
http://www.wankel-ag.de/entw.html
http://www.der-wankelmotor.de/Motoren/Rolls-Royce/rolls-royce.html (350 hp!)
http://www.der-wankelmotor.de/Motoren/UAV/Pats/pats.html
CU Gremlin.
Translated on 12-10-2026, 22:21.
x world one
Post22-01-2004, 21:19    Subject: Wankel Engine: How it Works & Benefits Quote
The sealing problem is probably the biggest issue with the Wankel engine. I believe the contact points of the rotor are particularly difficult to seal. Even the current Wankel in the RX8 still consumes oil like crazy, and Mazda even points out that this is normal. Furthermore, the fuel consumption of a Wankel engine is significantly higher than that of a conventional piston engine, but I don't know why. However, it has great RPM ranges icon_biggrin.gif.
Spritmonitor
Translated on 12-10-2026, 22:22.
WarLord
Post22-01-2004, 21:40    Subject: Wankel Engine: How it Works & Benefits Quote
But it has great rev ranges icon_biggrin.gif.
It's also something that Honda's VTec technology has. *g*
Best regards, WarLord.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Smoking engine after engine/turbo replacement Diesel Engine Technology
No new posts TDI Engine with Gas Transmission: Possible? Diesel Engine Technology
No new posts 1Z Motor Audi 80 B4: Make the engine more fuel-efficient Diesel Engine Technology
No new posts AEL engine in T4 - Ex-ACV Diesel Engine Technology
