Turbocharger Part Numbers: E vs. G
Daniel_Diesel
Post10-02-2004, 20:19    Subject: Turbocharger Part Numbers: E vs. G Quote
Hello.
I have a question.
I need a new turbocharger for my Passat 3BG 1.9 TDI 96kw AVF.
I've already removed my turbo, and the part number is 038 145 702 E.
'But the VW workshop gave me the part number 038 145 702 G.'
What is the difference between E and G icon_question.gif icon_question.gif?
Translated on 26-10-2026, 16:47.
Post10-02-2004, 21:08    Subject: Turbocharger Part Numbers: E vs. G Quote
The letter "E" was replaced by the letter "G".
Costs over 1000 euros.
"Part E was used from 01-02, and part G was used from 03 onwards."
Translated on 26-10-2026, 16:48.
mersente
Post11-02-2004, 21:33    Subject: Turbocharger Part Numbers: E vs. G Quote
Hello, so usually, when the letters have changed, it indicates an error or defect (accumulation/serial change).
So, if you take the new version, the error or defect is usually fixed.
Translated on 26-10-2026, 16:49.
Post11-02-2004, 21:54    Subject: Turbocharger Part Numbers: E vs. G Quote
It may be true that the letter representing the better version is different in case of errors.
However, this in no way allows for the reverse conclusion.
Here we have various letters, which could also simply be different parts.
The fuel injectors for the 1Z and AFN engines differ only in the last letter, and they are not interchangeable or indicative of a fault; they are simply different (184 vs. 205, referring to a hole size).
Translated on 26-10-2026, 16:50.
Daniel_Diesel
Post12-02-2004, 18:55    Subject: Turbocharger Part Numbers: E vs. G Quote
Yes, thank you for the information.
I just bought the G version.
I hope this one lasts longer than my old turbocharger, which failed after only 74,000 km. icon_evil.gif
mersente
Post12-02-2004, 20:43    Subject: Turbocharger Part Numbers: E vs. G Quote
Hello Martin, of course, one or two different ending characters don't necessarily mean the parts are compatible, and I completely agree with you. However, in some cases, the ending might change, as in this instance. Sometimes, even the entire part number can change.
Translated on 26-10-2026, 16:51.
No new posts Turbocharger Repair 1.9 TDI ASZ Troubleshooting & Guides
No new posts Transporter 7D Turbocharger Pipes: ACV Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Whistle: Documentary Analysis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG 17 vs. VTG 15: What's the Difference? Diesel Engine Technology
No new posts AAT vs. AEL: What's the Difference? Diesel Engine Technology
No new posts 1.9 TDI vs. 2.5 TDI: Differences in smoke emissions? Diesel Engine Technology
No new posts Control Unit Differences On-Board Diagnostics (OBD)
