Gear Compatibility: A Comprehensive Guide
sallafranz
Post02-01-2004, 17:00    Subject: Gear Compatibility: A Comprehensive Guide Quote
Warm greetings!
I own an A6 Avant with an AJM engine and a 5-speed transmission.
Which 6-speed transmission can I install retroactively?
Of course, I started by using the search function, and I came across the following:
Transmission assignment A6 AJM: DUK (gearbox).
Gearbox options for Passat models with AJM and ATJ engines: DUK, EHW, ELN, etc.
Can I now assume, for example, that I can install, say, an ELN transmission in my A6?
DUK and ELN differ in: 1. The diameter of the clutch disc, and 2. The dual-mass flywheel.
Thank you very much for any response.
Franz.
Translated on 08-10-2026, 23:03.
No new posts Gear Compatibility: Find Your Perfect Match Diesel Engine Technology
