Central Locking Problems: Troubleshooting & Repair
manx
Post30-12-2003, 10:57    Subject: Central Locking Problems: Troubleshooting & Repair Quote
'The central locking system on my Golf 4 is malfunctioning. Every time I unlock the driver's side, the button on the passenger side pops up, but then retracts about 1/4 of the way back, so the passenger door cannot be opened from the outside. I have to use the manual door opener on the inside of the passenger door every time. Does anyone else experience this problem? It would be great if someone had a tip.'
Best regards and a happy New Year.
Manx.
Translated on 27-10-2026, 0:35.
Marco
Post31-12-2003, 10:28    Subject: Central Locking Problems: Troubleshooting & Repair Quote
It sounds like your central locking system isn't original but was added later. I also installed a Waeco central locking system in my first Golf IV (it was quite a job, even the window panes had to be removed). In any case, I've only observed this behavior with the button bouncing back on systems that were added after the fact. I haven't seen it on systems that were originally installed. So, let us know if it's the original central locking system or not! In any case, I would recommend removing the door panel on the passenger side and taking a closer look at the actuator motor.
Translated on 27-10-2026, 0:37.
huskydoctor2002
Post31-12-2003, 16:06    Subject: Central Locking Problems: Troubleshooting & Repair Quote
I had a similar problem with my VW T4. In my case, it was the driver's side door. I could open and close the door without any problems using the remote control or the key. However, if I tried to open the door by pulling the door handle, the central locking system would automatically re-lock. The only way to override this was to hold the door lock button on the central locking system upwards. Then it would work.
My car door lock was broken. A small pin inside had snapped, which prevented the central locking button from fully retracting, causing the door to re-lock itself every time it was opened. The door lock has now been replaced and is working perfectly again.
Best regards, huskydoctor.
Translated on 27-10-2026, 0:38.
Wuschelwanda
Post31-12-2003, 16:11    Subject: Central Locking Problems: Troubleshooting & Repair Quote
That sounds like the door lock might be defective, which we've experienced at our company before.
Translated on 27-10-2026, 0:39.
manx
Post03-01-2004, 14:58    Subject: Central Locking Problems: Troubleshooting & Repair Quote
The central processing unit (CPU) is original. Thank you for the tips; I will follow up on each suggestion and let you know what I find.
Manx.
Golf 4 TDI.
Year of manufacture: 2000, ALH engine, 90 horsepower.
Tuned with an Alpine chip.
Translated on 27-10-2026, 0:40.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.5 TDI AAT Problems: Common Issues & Fixes Diesel Engine Technology
No new posts ABS Problems: Causes and Solutions On-Board Diagnostics (OBD)
No new posts ALE: Troubleshooting GRA Issues in MKB Diesel Engine Technology
No new posts 2.5 TDI Problems: Common Issues & Solutions Diesel Engine Technology
