TDI Frame Driver Seat
bekertje2
Post03-01-2004, 18:14    Subject: TDI Frame Driver Seat Quote
Hello.
I have a terrible cracking noise coming from the backrest of the driver's seat in my Passat TDI 1.9PD (05/2000, 70,000 km).
I went to an auto upholstery specialist, and he said that something was probably broken on the lumbar support, and that he would have to replace the entire frame of the backrest. He can reuse the seat cover.
I have the following questions about this:
- Can the ramen installation and airbag replacement be done by myself?
- Is it possible to remove the outer casing myself so I can inspect it and see what's defective?
- Does anyone happen to know approximately how much this frame will cost at a VW dealership?
Translated on 17-10-2026, 10:56.
bekertje2
Post10-01-2004, 18:41    Subject: Crackling Gone: [Product/Service] Now Silent Quote
I've managed to fix the crack in the meantime. If you want to know more, you can read about it here:
http://passat3b.de/phpBB2/viewtopic.php?t=9987
Translated on 17-10-2026, 10:57.
No new posts Golf Seat Disease: Causes & Solutions Transmission, Chassis, Body & Interior
No new posts Ibiza 6L Driver Seat Wobbles - Fix It! Transmission, Chassis, Body & Interior
No new posts Loose Car Seat: Fix Slipping & Wobbly Seat Transmission, Chassis, Body & Interior
No new posts Golf 4 driver's seat has play - Solution, Cause? Transmission, Chassis, Body & Interior
