OlliP Guest
12-01-2004, 11:00 Subject: TDI (110 hp) engine failure! |
This morning, my TDI gave me a bit of a headache. During his commute to work, he suddenly lost his motivation!
(Maybe he realized that I'm not really into it either!!)
But seriously:
Suddenly, the 'glow plug' (preheating lamp) started blinking, and the next time I took my foot off the accelerator, the engine stalled - what the heck?
Okay - stopped - key turned - engine running!
After about 3 minutes of driving, the same thing happened again.
This time, it wasn't the fuel; the engine kept running until the traffic light, and then it turned off again. Turn the key and the engine starts right up again!!!
But after 3 minutes, it starts again.
Okay, I'm at work now, but like my TDI, I don't feel like doing my job!
'My TDI is sick.'
Does anyone have any ideas about the problem with my TDI?
THANK YOU.
Olli.
Marco Guest
12-01-2004, 11:04 Subject: TDI (110 hp) engine failure! |
Hi Oli,
Without further thought, please search for 'Relais 109' within this forum.
OlliP Guest
12-01-2004, 23:00 Subject: TDI (110 hp) engine failure! |
I took my HOPA module out tonight.
And now it's running again!!!
Error memory cleared, and everything is quiet now.
I'll test the HOPA system again this weekend.
'Thank you.'
Olli.
Julian Guest
12-01-2004, 23:27 Subject: TDI (110 hp) engine failure! |
Didn't feel like thinking either? To revitalize your cognitive abilities: [img][/img]http://www.cheesebuerger.de/smilies/brutal/16.gif{MARKER}
OlliP Guest
13-01-2004, 8:31 Subject: TDI (110 hp) engine failure! |
@Julian
... but you're being 'harsh' with me!!!
I've thought about it and found the error. This.
I wanted to share that here already.
Forgive me? *begging*
CU
Olli.
Julian Guest
13-01-2004, 9:32 Subject: TDI (110 hp) engine failure! |
[img][/img] ;)http://www.cheesebuerger.de/smilies/schilder/24.gif{MARKER}...
OlliP Guest
13-01-2004, 14:21 Subject: TDI (110 hp) engine failure! |
13-01-2004, 18:04 Subject: TDI (110 hp) engine failure! |
OlliP wrote: | I took out my HOPA module tonight.
I'm going to test the HOPA again this weekend | .
Hi Olli,
If you had mentioned something about a power box, we might have figured it out, considering the flashing indicator light...
Do you remember what the error codes were? Gruß Ulf
Profile PM Garage |
OlliP Guest
14-01-2004, 11:24 Subject: TDI (110 hp) engine failure! |
@Ulf
I have saved the errors in a log file.
and I will also post them tonight!
Thank you.
Olli.
