OBD Interface: Is €40 a Good Price?
WarLord
Post22-01-2004, 21:26    Subject: OBD Interface: Is €40 a Good Price? Quote
'Hmm, I was thinking about getting a ready-made diagnostic connector from eBay, so I wouldn't have to worry about sourcing the connector and doing the soldering. Is 40 euros a reasonable price for an adapter, or is that too much? How much did your adapter with connector and circuit board cost? By the way, if I build the interface myself, I probably won't finish it in two years (I haven't had time for things like that lately).'
Best regards, WarLord.
Translated on 16-09-2026, 19:37.
joergs
Post22-01-2004, 21:46    Subject: OBD Interface: Is €40 a Good Price? Quote
'What do you think about a ready-made interface from our host? It's a bit more expensive than the stuff you find on eBay. Do you have a 1Z? If so, I'd advise against buying anything from eBay. I've built countless interfaces, and they worked everywhere except on my 1Z. It took an adapter with a MAX232 chip to finally get it working. And you can find exactly that kind of thing from Rainer. Plus, if it doesn't work, you'll get expert support here, which might not be the case with eBay products. Also, you might be supporting the forum a little bit. '
Translated on 16-09-2026, 19:38.
WarLord
Post22-01-2004, 21:48    Subject: OBD Interface: Is €40 a Good Price? Quote
Yep, I have a one-bedroom apartment.
Translated on 16-09-2026, 19:39.
x world one
Post22-01-2004, 22:01    Subject: OBD Interface: Is €40 a Good Price? Quote
I was also considering that. Unfortunately, my laptop doesn't have a serial port, and Rainer only offers adapters that use a serial port. Or would they also work with a USB-to-serial adapter?
Spritmonitor
WarLord
Post22-01-2004, 22:08    Subject: OBD Interface: Is €40 a Good Price? Quote
I've read that there are often problems there.
Translated on 16-09-2026, 19:40.
joergs
Post23-01-2004, 7:24    Subject: OBD Interface: Is €40 a Good Price? Quote
I've already posted about USB-to-RS232 adapters and provided some working solutions. Please search for those posts.
By the way, I also tried the one from Reichelt. It seems there was a supplier change, but it works fine under XP (at least for me). VAG-COM didn't have any problems with it! The only thing to 'complain' about is that this device occasionally causes a blue screen after prolonged use. But for less than 15€, you can probably live with that! As far as I know, Rainer is also working on a USB-ISO9141 adapter.
x world one
Post23-01-2004, 10:00    Subject: OBD Interface: Is €40 a Good Price? Quote
Okay, thanks. I'll ask Rainer about it via private message. Thanks.
Spritmonitor
Translated on 16-09-2026, 19:41.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts USB Interface not recognized On-Board Diagnostics (OBD)
No new posts Ross-Tech USB interface not found! On-Board Diagnostics (OBD)
No new posts OBD-2 interface does not work with USB serial adapter. Diesel Engine Technology
No new posts USB CAN Interface: Driver Installation Issues? On-Board Diagnostics (OBD)
