Oil pressure problem solved on 1z TDI!
joe
Post13-06-2002, 9:09    Subject: Oil pressure problem solved on 1z TDI! Quote
'Suddenly, my 1z TDI engine in my T3 bus lost oil pressure. My initial suspicion fell on the turbocharger, as there was a black liquid visible on the exhaust. So, I removed the turbo, but it looked completely fine, with no signs of oil.' The black liquid on the exhaust was therefore just wet soot (damn rainy weather). icon_twisted.gif
So, the search continued until I found the vacuum pump, and sure enough, the retaining screw was broken, and the pump had moved upwards, preventing it from driving the oil pump anymore.
The engine only has 60,000 km on it.
I suppose the torque applied to the screw was too high.
Hopefully, the engine or turbocharger hasn't suffered any consequential damage.
Translated on 04-07-2026, 4:27.
Post13-06-2002, 10:40    Subject: Oil pressure problem solved on 1z TDI! Quote
Hello, it's great that you found the error, and thank you for the feedback!
Translated on 04-07-2026, 4:28.
This topic is locked, you cannot edit or reply. Third gear shifting/synchronization (resolved) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Pressure Problem? Troubleshooting Guide. Diesel Engine Technology
No new posts Audi 8E Old Oil Pressure Problem Gasoline Engine Technology
No new posts Oil Pressure Problem AKE V6 TDI 180 HP Diesel Engine Technology
This topic is locked, you cannot edit or reply. Engine Mounts 3BG (Solved) Diesel Engine Technology
