CR-SG: Why Only 6 Injectors?
Martin R
Post24-01-2004, 19:30    Subject: CR-SG: Why Only 6 Injectors? Quote
As is well known, a common-rail control unit (at least in MAN engines) can only control 6 injectors.
That's why V10 engines require two engine control units (ECUs) that are connected to each other via a CAN bus.
Does anyone know why they don't build a system that can process all 10 injectors? Surely, it should be possible to develop something like that.
Translated on 18-10-2026, 8:23.
mhernach
Post24-01-2004, 22:33    Subject: CR-SG: Why Only 6 Injectors? Quote
I suspect it's cheaper to install two control units than to create a new one.
I also suspect that it depends on the processing power. In other words, it might be too slow (processing too much information).
But, as I said, these are just speculations...
MIkl
Translated on 18-10-2026, 8:24.
leolotus
Post25-01-2004, 1:27    Subject: CR-SG: Why Only 6 Injectors? Quote
That's why V10 engines require two control units, which are then connected to each other via a CAN bus.
Quantities, quantities, and quantities again.
Translated on 18-10-2026, 8:25.
Post25-01-2004, 9:27    Subject: CR-SG: Why Only 6 Injectors? Quote
Martin R wrote:
Does anyone know why they don't build injection molding machines that can process all 10 injectors at once?
As far as I understand, this is due to the processing speed of the engine control unit (ECU). While it would be possible to control more injectors, it would require processors that are so expensive that it would be cheaper to install two ECUs.
By the way, there's also a similar "magic" limit in the context of the Bie PD: 5!
Translated on 18-10-2026, 8:26.
WarLord
Post25-01-2004, 14:02    Subject: CR-SG: Why Only 6 Injectors? Quote
By the way, there's also a similar magical limit in Bie PD: 5!
Is there a new control unit available now that can control more PD elements? I read something about that somewhere.
Best regards, WarLord.
Translated on 18-10-2026, 8:27.
Post25-01-2004, 18:15    Subject: CR-SG: Why Only 6 Injectors? Quote
WarLord wrote:
Is there a new control unit available now that can control more piezo injectors? I read something about it somewhere.
So, with the EDC16 series (the currently available version), there were still 5.
Does anyone have more up-to-date information?
Translated on 18-10-2026, 8:28.
Gremlin
Post25-01-2004, 18:26    Subject: CR-SG: Why Only 6 Injectors? Quote
I'll take a look tomorrow.
CU Gremlin.
Post26-01-2004, 10:16    Subject: CR-SG: Why Only 6 Injectors? Quote
Bertil wrote:
So, with EDC16 (the currently active series), there were still 5.
According to the documents available to me, the PD-EDC16 also has a 6-cylinder engine.
However, the CR system is specified with 8 cylinders in that case.
Translated on 18-10-2026, 8:29.
Gremlin
Post26-01-2004, 13:21    Subject: CR-SG: Why Only 6 Injectors? Quote
I did a quick, superficial search.
EDC-16 for 6-cylinder engines with direct injection (DI) and common rail (CR).
MS6.2/I: Truck PD (UI / UIS) up to 8 cylinders.
Unfortunately, I don't have access to EDC-17 or ME(D)7.
CU Gremlin.
Translated on 18-10-2026, 8:30.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The Electric Car - Why It Isn't Taking Off Technical Articles
No new posts TDI Injectors: 2.7L & 3.0L V6 Engines Diesel Engine Technology
No new posts Injection Nozzles: Year of Manufacture On-Board Diagnostics (OBD)
No new posts Piezo Injectors: 3.0 TDI - Installation & Problems Diesel Engine Technology
No new posts Injector Problems: Common Issues & Solutions Diesel Engine Technology
