I recently bought a Passat Variant V6 with automatic transmission (Tiptronic), manufactured in October 1999. However, I believe it's not performing as it should.
Problem 1: Fuel consumption at 150-160 is approximately 9.8 (city 12-13 L
). I read on a Forem forum that values as low as 8.3 L are also possible? So, it's actually not really drivable below 7.4 liters (highway at 60-90 km/h, driving calmly). Can anyone share experiences with the automatic transmission that show lower consumption? Max speed with long acceleration, according to the speedometer, is 208 km/h. The engine runs smoothly and achieves 0-100 km/h in 10.3 seconds!
I have the feeling that the car isn't pulling like it should for a V6 (high
The mass airflow sensor is new
, but it's showing very low values (not reaching the target value).
Boost pressure control: OK (2121 millibar).
Since the timing belt wasn't replaced at the authorized service center, I have concerns.
The fuel injection pump is misaligned.
We logged something incorrectly with the VAG COM device.
Full load.
Engine speed specification. Start. Actual start. Cold start valve.
TIME 3800-4200 rpm 8-12 *BTDC 6-14 *BTDC
STAMP /min °ATDC °ATDC %
1.21 1949 4.0 4.8 63.9
2.41 2204 4.4 4.6 58.0
3.61 2459 5.0 5.0 51.7
4.81 2714 5.6 5.8 49.3
6.01 2970 6.4 6.6 46.6
7.21 3202 7.2 7.4 45.4
8.41 3434 7.8 8.2 43.0
9.61 3642 8.6 8.8 42.2
10.81 3828 9.4 9.4 38.3
12.01 4014 10.0 10.6 38.3
13.21 4176 10.0 10.2 38.7
Jogging.
STAMP /min · ATDC · ATDC %
0.81 742 1.0 1.0 74.6
2.01 742 1.0 1.2 77.3
3.21 742 1.0 0.6 78.9
4.41 742 1.0 1.2 76.1
Shouldn't the duty cycle sometimes increase to 95%?
Does this indicate a misadjusted fuel injection pump?
Engine speed / RPM
MAF sensor: Specified value
MAF sensor: Actual value
EGR valve duty cycle
TIME 740-840 180-270 mg/H 160-290 mg/H 40-75%
STAMP /min mg/R mg/R %
0.81 1856 867.4 537.7 95.5
2.01 2111 879.2 628.0 95.5
3.21 2366 879.2 714.4 95.5
4.41 2645 879.2 757.5 95.5
5.61 2900 879.2 777.2 95.5
6.81 3132 879.2 785.0 95.5
8.01 3364 879.2 777.2 95.5
9.21 3573 879.2 769.3 95.5
10.41 3782 879.2 741.8 95.5
11.61 3967 879.2 726.1 95.5
12.81 4130 879.2 702.6 95.5
Air volume decreases as speed increases, starting from a certain point.
Has anyone ever logged in and seen the number 879?
