GRA Installation/Activation Audi 80 TDI 93
T2-TDI
Post23-11-2003, 12:50    Subject: GRA Installation/Activation Audi 80 TDI 93 Quote
I have a 1Z TDI engine from a 1993 Audi 80 in my T2. This wiring harness doesn't yet have the wiring integrated for the GRA function.
'Does anyone perhaps have the complete PIN configuration for the control unit for this function? The Audi wiring diagram doesn't provide any information on this.'
Control unit No. 0 281 001 185.
Greetings, Andi.
Translated on 06-10-2026, 15:40.
mersente
Post09-02-2004, 22:13    Subject: GRA Installation/Activation Audi 80 TDI 93 Quote
Hi Andi, it seems the control unit is not designed for GRA (presumably referring to a specific system or function).
Instead, a dedicated control unit with a vacuum pump is used.
Translated on 06-10-2026, 15:41.
Post09-02-2004, 22:36    Subject: GRA Installation/Activation Audi 80 TDI 93 Quote
Hi.
I highly doubt you have a 1Z in your T2 icon_smile.gif.
It will be a Type 2 T3 - but I don't call my Golf a Type 1, even though it is icon_smile.gif.
The number you mentioned doesn't fit the VAG parts numbering system.
I would have expected something like "028 906 021 AF"...
Is that a Bosch part number?
For these STGs, I can provide you with the GRA plan.
Translated on 06-10-2026, 15:42.
palmstrollo
Post10-02-2004, 0:01    Subject: GRA Installation/Activation Audi 80 TDI 93 Quote
Doch, die Steuergerätenummer stimmt. Hab' ich in meinem 80er TDI 1/93 ebenfalls. Aber auch mein freundlicher meinte auf Nachfrage, dass bei diesem Modell nix mit GRA geht. Too bad.
Hermann.
Translated on 06-10-2026, 15:43.
Post10-02-2004, 7:44    Subject: GRA Installation/Activation Audi 80 TDI 93 Quote
Funny situation.
If you write it in the VAG format, it would be 028 100 118 5, which would indicate a motor part (the second block starts with 1).
Bei mir (und allen anderen) ist es ein Elektrik Teil (2. Block number 9, front.
Well, in that case, I'm afraid I can't comment on that.
Does it also have a 68-pin connector?
m
DocSnydor
Post10-02-2004, 8:23    Subject: GRA Installation/Activation Audi 80 TDI 93 Quote
I can confirm this 'urban legend': it's not so easy to retrofit a GRA (Gas Return System) to the early 1Z engines, and also to the early TDI engines in the T4 (MKB ???). My local mechanic was even surprised that I had retrofitted a GRA to my '94 1Z. He was absolutely certain that it wouldn't be possible... icon_lol.gif
@dieselmartin
I hadn't really noticed the numbers before. Do you have a link, or can you explain how to decipher VAG part numbers? I find that very interesting...
Translated on 06-10-2026, 15:45.
Post10-02-2004, 12:00    Subject: GRA Installation/Activation Audi 80 TDI 93 Quote
@ Doc
Go to VW and take a look at the Edgar icon_smile.gif.
1H0 906 021 AF (fictitious part number)
1H0 == Golf 3
9xx == Electricity
021 == Arbitrary, the part itself.
AF == Addendum, used when there are different versions.
To the second block.
1 - motor
2 - Transmission and exhaust.
3 - Front axle?
4 - Rear axle?
5 -
6 -
7 - Lever mechanism, pedal.
8 - Construction (almost everything else)
9 - Electricity
That was just off the top of my head, and I'm not entirely sure about it anymore.
Translated on 06-10-2026, 15:46.
DocSnydor
Post10-02-2004, 13:23    Subject: GRA Installation/Activation Audi 80 TDI 93 Quote
1 - motor
3 - Front axle?
4 - Rear axle?
5 -
6 -
9 - Electricity
Translated on 06-10-2026, 15:48.
vagtuning
Post10-02-2004, 21:49    Subject: GRA Installation/Activation Audi 80 TDI 93 Quote
I'm correcting something...
2. Fuel and exhaust system.
3.... Transmission.
4. Front axle.
5. Rear axle.
6. Front and rear brakes.
Translated on 06-10-2026, 15:49.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Activate GRA in Audi A2 Diesel Engine Technology
No new posts Activate GRA on a Passat manufactured in 11/97 On-Board Diagnostics (OBD)
No new posts Activate camera-based speed limit display Audi A6 4G On-Board Diagnostics (OBD)
No new posts Cruise Control Installation: Audi 80 TDI 90PS Diesel Engine Technology
