575 limit exceeded
René_S
Post03-03-2004, 20:38    Subject: 575 limit exceeded Quote
Hello, my AKN (automatic keyboard noise) is experiencing occasional, slight performance drops. The error code '575 - Limit exceeded' is stored in the fault memory.
The system's default setting 11 shows a pressure of 979 mbar with the N75 valve closed, and 1081 mbar with the valve open.
During a measurement run in measurement block 11, the pressure readings sometimes show an excess of 110 mbar.
The hose from the N75 valve to the VTG is in good condition and has been additionally secured with hose clamps.
Can the N75 valve be repaired/cleaned? ... Perhaps there's a clogged filter upstream of the N75 valve?
Sure, here's the translation:
'Thank you in advance.'
René.
mersente
Post03-03-2004, 22:56    Subject: 575 limit exceeded Quote
Are the VTG rods functional? Are the guide vanes functional?
René_S
Post04-03-2004, 16:58    Subject: 575 limit exceeded Quote
The VTG (Variable Transmission Gear) linkage is loose. How can I check the guide vanes? I was under the impression that the VTG strut is connected to the guide vanes.
The linkage moves approximately 15mm in idle, with or without vacuum applied.
René.
PrivatBereich
Post04-03-2004, 17:05    Subject: 575 limit exceeded Quote
Yes, the VTG rod and guide vanes are connected. It seems okay.
Okay, please provide a log of your boost pressure readings, including the valve control signals, and post it here. (Ideally, provide multiple logs.) 'Definitely one where the error occurred!'
Private.
No new posts P0299 Error: Boost Control System Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A6 4B 2.5 TDI AGR limit exceeded On-Board Diagnostics (OBD)
No new posts TDI PD Turbo: Overboost Issue & Diagnostic Log Upload
This topic is locked, you cannot edit or reply. Boost Pressure Control: Limit Exceeded Diesel Engine Technology
No new posts Boost Pressure Control: Limit Exceeded Diesel Engine Technology
