Timing Belt Replacement for Audi VW Fiat
zecke24
Post19-11-2003, 2:31    Subject: Timing Belt Replacement for Audi VW Fiat Quote
Hello!
I really need to get my timing belt replaced soon.
Can someone tell me which camshaft locking tool (Hazet part number) I need?
Does anyone perhaps have a drawing with dimensions?
And what else is special about it?
Best regards, Arne.
Translated on 21-08-2026, 17:31.
mersente
Post09-02-2004, 23:27    Subject: Timing Belt Replacement for Audi VW Fiat Quote
AVF is a direct injection engine, so you don't need a camshaft timing tool.
A 6mm drill bit for camshaft locking (for VW locating pin Matra 3359).
Then you will need a crankshaft locking tool (Matra t 10050) or a paint marker to mark the position of the crankshaft pulley.
The well-known two-hole tensioner.
If you have a 3B, A4, or A6, do you also need a two-hole drill for the fan blade?
I recommend replacing all the pulleys, including the tensioner pulley and the water pump.
Also, also replace the central bolt on the crankshaft (it's a stretch bolt and tends to loosen, which can cause engine damage).
If you need to know anything else, just ask.
(Please note: The conversion process takes approximately 2-3 hours for the specified models.)
Translated on 21-08-2026, 17:33.
Post10-02-2004, 8:20    Subject: Timing Belt Replacement for Audi VW Fiat Quote
"Hi,"
For a permanent magnet (PM) motor, you'll need this:
http://www.hazet.de/deutsch/produktinfo/pdf/2588_3.pdf
Translated on 21-08-2026, 17:35.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post10-02-2004, 11:40    Subject: Timing Belt Replacement for Audi VW Fiat Quote
...just for information: The Hazet set (i.e., all three tools) costs approximately 70 euros.
not that the feeling of helplessness only sets in when you're already in the store icon_smile.gif)
Dirk.
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Timing belt replacement for transversely mounted PD engine Troubleshooting & Guides
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts V6 TDI Timing Belt Replacement, AFB Diesel Engine Technology
No new posts Timing Belt Replacement 1 Diesel Engine Technology
No new posts Timing belt replacement AJM Diesel Engine Technology
No new posts Timing belt replacement for T3 engines (KY, CS, JX) Diesel Engine Technology
