Timing Belt Replacement SDI Engine -AGP- Injection Start
Dalitroll
Post19-07-2003, 18:38    Subject: Timing Belt Replacement SDI Engine -AGP- Injection Start Quote
Dear readers,
I just replaced the timing belt on my Golf IV SDI, engine code -AGP-. Now, I want to use the VAG COM tool to check the fuel injection timing.
'Where can I find the diagram showing the start of fuel injection (as a function of fuel temperature and other factors)? In the past, this was often done using a micrometer. Unfortunately, I'm not quite familiar with VAG-COM yet, and most importantly, I'm missing the diagram.'
Are there any SDI owners who have the wiring diagram for the Golf IV? Unfortunately, the Polo has a different diagram.
Thank you very much.
Translated on 17-10-2026, 2:13.
mersente
Post11-02-2004, 20:16    Subject: Timing Belt Replacement SDI Engine -AGP- Injection Start Quote
Hello, it's been a while, but here's the information:
Up to production date 04/99: Field 2: 55 (Injection start); Field 9: 90 (Fuel temperature).
Field 2: 51 (Bb) ; Field 9: 110 (Kt)
You can create a diagram from the data.
From production date 05/99: Field 2, range 25-78 (ideal 55); Field 2: 90 and above.
Translated on 17-10-2026, 2:14.
No new posts Timing belt replacement for transversely mounted PD engine Troubleshooting & Guides
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Timing Belt Replacement ATD Engine Diesel Engine Technology
No new posts Timing Belt Replacement AJM Engine Diesel Engine Technology
No new posts Bad Timing Belt Replacement PD Engine Diesel Engine Technology
No new posts Very early fuel injection start On-Board Diagnostics (OBD)
