can someone please
Explain groups 08 and 09.
8,0,Injection Quantity Limitation **Done at WOT**(See label file, I.Q.= Inj. (Quantity)
Read values when the engine speed reaches 3000 rpm.
8.1, Engine speed, rpm
8.2, I.Q. Driver's license required, 40.0-42.0 mg/H.
8.3, I.Q. via rpm (Torque), 35.5-36.5 mg/H.
8.4, I.Q. via air mass, 36.0-39.0 mg/H.
;#4 Injection quantity limited due to air mass being drawn in (to prevent smoke).
9.0, Injected Quantity Limitation.
9.1, Engine speed, rpm
9.2, Injection Quantity, CC active.
9.3, Injection limit, during automatic transmission shift.
9.4, ,
It's quite straightforward. Drive at 1300 rpm and floor the accelerator. Then, channel 8.2 will be at its maximum, and most importantly, channel 8.3 will limit the amount It's not as easy as it seems, so how do workshops actually do it?
I am selling a new turbocharger
for me, the logs seem more like they indicate a stuck EGR valve
How did you disable it?
CU Gremlin.
