Thermostat: Buy, Install, Repair & More
tim27
Post11-06-2002, 17:28    Subject: Thermostat: Buy, Install, Repair & More Quote
'Since yesterday, my TDI 1Z engine hasn't been warming up properly. After driving for 15 kilometers, the water temperature and oil temperature are only around 80°C, and that's with an outside temperature of 20°C.'
I think my thermostat might be broken, or maybe it's stuck.
What do you think about that?
Translated on 25-08-2026, 20:13.
Michael II
Post11-06-2002, 17:32    Subject: Thermostat: Buy, Install, Repair & More Quote
I've experienced that before too (it even happened once in a 1Z engine, in an Audi A4).
It was the thermostat back then. Don't forget to replace the sealing ring from the housing when you change it.
Tschüss
Michael II
Translated on 25-08-2026, 20:14.
Wesso
Post11-06-2002, 18:59    Subject: Thermostat: Buy, Install, Repair & More Quote
What other temperature are you talking about?
Okay, mine is a 2-star TD, and it only fully charged after 12km.
warm, which for me means an oil temperature of 80°C.
He just ignores it when I really put my foot down.
And the thermostat is fine, as it was recently replaced.
sw
Translated on 25-08-2026, 20:15.
tim27
Post11-06-2002, 21:18    Subject: Water Temperature: Check Current Readings Quote
The water temperature was 20°C, the outside temperature was around 6-7°C, and after approximately 6-7 kilometers, the engine temperature reached 90°C, with the oil temperature at around 70°C, all under normal driving conditions.
Currently, with a somewhat faster driving style, the water temperature reaches only 90° after about 12 km. The oil temperature has essentially 'heated up' the water, causing both to become warmer simultaneously.
I bought a thermostat today for €12.25, including an O-ring.
Translated on 25-08-2026, 20:17.
No new posts Thermostat V6 TDI Diesel Engine Technology
No new posts Thermostat: G62, G83 Coolant Temp. Issues On-Board Diagnostics (OBD)
No new posts Where is the thermostat located on a TDI BLS Golf 5? Diesel Engine Technology
No new posts Differenz Kühlwassertemperatur Thermostat und Geber ? Diesel Engine Technology
