What information does the consumption signal provide?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
dieter
Karma: +13 / -0   Thank you, like it!
Post26-05-2004, 10:23    Subject: What information does the consumption signal provide? Quote
Unfortunately, I couldn't find anything specific.
The MSTG generates a signal for the MFA, which contains information about the consumption. The output is provided as PWM (Pulse Width Modulation) or pulse frequency/duration. Whether any of that is correct doesn't matter; I can always measure it again if necessary, and both can be evaluated analogously.
But what information is contained in this signal: consumption/time or consumption/distance?
Both options are possible, as the MSTG also has the speed signal.
If the information available were consumption per distance, a real-time consumption display could be implemented using simple analog technology.
Greetings.
dieter
T3 syncro 16 AFN
Translated on 07-07-2026, 5:59.
Gremlin
Post26-05-2004, 11:09    Subject: What information does the consumption signal provide? Quote
usually liters per hour.
The combination instrument handles all the other calculations.
CU Gremlin.
Translated on 07-07-2026, 6:00.
dieter
Post26-05-2004, 15:49    Subject: What information does the consumption signal provide? Quote
Okay, then I guess I should start looking for a medical assistant.
dieter
Theresias
Post26-05-2004, 22:26    Subject: What information does the consumption signal provide? Quote
The consumption signal provides an instantaneous value (which should represent the current cycle of the fuel pump) that is then converted and displayed on the instrument cluster.
'With an average value like liters per hour, it would not be possible to display the current consumption rate.'
Avatar-Jan6K
Post26-05-2004, 22:38    Subject: What information does the consumption signal provide? Quote
Sure?
"As far as I know, the MSG (presumably a module or system) integrates the injected fuel amounts and calculates a consumption rate per unit of time. From this, as Grenlin mentioned, the consumption in liters per 100 km can be calculated if you have the speed (which the instrument cluster provides)."
l/h is not an average value, but a calculated instantaneous value for flow rate per unit of time - you can easily convert from microliters per millisecond to l/h.
It's not possible to measure the fuel consumption directly at the fuel pump because not all the fuel that is pumped is actually consumed; you would have to factor in the return flow.
Jan.
1Z5 CFHF / AHB H4D
Translated on 07-07-2026, 6:01.
Gremlin
Post27-05-2004, 5:50    Subject: What information does the consumption signal provide? Quote
The consumption signal provides an instantaneous value (which should be the current cycle of the fuel pump) that is then converted in the instrument cluster.
With an average value like liters/hour, it is not possible to display the current consumption.
liter / h IS a current value icon_wink.gif
CU Gremlin.
Translated on 07-07-2026, 6:03.
wolfi_b
Post27-05-2004, 8:58    Subject: What information does the consumption signal provide? Quote
The fuel injection pump returns a PWM signal indicating the amount of fuel injected. "With the speed signal and an analog multiplier (operational amplifier circuit), it should be quite simple to create an analog display, in my opinion."
Wolfi.
No new posts Information about glow plug spark plugs (glow plugs) Technical Articles
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine temporarily maintains RPM, automatically increases... General Tips
No new posts Information zum Förderbeginn - Einspritzzeitpunkt On-Board Diagnostics (OBD)
No new posts Consumption signal MFA On-Board Diagnostics (OBD)
No new posts Consumption Signal: Understanding & Optimization Diesel Engine Technology
No new posts T4 ACV: Find Consumption Signal Pin (1997) Diesel Engine Technology
