Speed sensor location: VW Golf B4 TDI 1Z (1993)
palmstrollo
Post26-02-2004, 21:40    Subject: Speed sensor location: VW Golf B4 TDI 1Z (1993) Quote
Hi.
While reading through the threads, a potential solution for my slight jerking at approximately 1250-1300 RPM emerged: disconnecting the speed sensor on the transmission. icon_evil.gif Even though this might confirm a faulty flow meter in the process.
'Where exactly is this sensor located? I haven't been able to find it yet. I only found the connector for the reverse light.'
Since my odometer is advancing intermittently (though consistently intermittently), a faulty sensor could also be the cause.
Thank you for your help with the search.
Hermann.
Translated on 19-08-2026, 1:19.
audi 80 tdi
Post26-02-2004, 22:58    Subject: Speed sensor location: VW Golf B4 TDI 1Z (1993) Quote
hello
If I remember correctly, the sensor and connector are located on the left side, high up on the differential. If you open the hood and look between the brake and the tie rod from the front, you should be able to see it. But what does the speed signal have to do with the engine?
christian
Translated on 19-08-2026, 1:21.
Post26-02-2004, 23:28    Subject: Speed sensor location: VW Golf B4 TDI 1Z (1993) Quote
audi 80 tdi wrote:
but what does the speed signal have to do with the motor?
.... Again, for those taking notes (for the 100th time): icon_rolleyes.gif
The speed signal goes to the engine control unit (ECU), and from there, it controls the speedometer. It is also used to manage various comfort functions (e.g., jerk damping, coasting deceleration, etc.).
Roadagain
Post27-02-2004, 10:09    Subject: Speed sensor location: VW Golf B4 TDI 1Z (1993) Quote
'I've had this problem since I bought the car.'
It says there's a faulty speed signal when I read the error codes. It's also happening in a Passat, year of manufacture 1993, with a 1Z engine.
I was looking for the sensor. This thing definitely has a speedometer cable. And I haven't found a sensor either. I've already been to VW twice. When they read the error codes, it shows the same result. Then the master mechanic looked under the hood, and he had a questioning look on his face; he said, 'It does have a speedometer cable.'
And then I was left standing there, with no idea why.
Perhaps someone here knows something about it.
Greetings.
Translated on 19-08-2026, 1:23.
Post27-02-2004, 10:29    Subject: Speed sensor location: VW Golf B4 TDI 1Z (1993) Quote
Roadagain wrote:
I was looking for the sensor. That thing definitely has a speedometer cable. And I haven't found a sensor either. I've already been to VW twice. When they read the error codes, it always shows the same result. Then the master mechanic looked under the hood, and he had a question mark on his face; he said, "It does have a speedometer cable."
Early models of the Audi 80 and similar cars actually had a speedometer cable!
To my knowledge, a sensor was installed in the speedometer to provide the engine control unit (ECU) with a speed signal.
Translated on 19-08-2026, 1:24.
palmstrollo
Post03-03-2004, 22:36    Subject: Speed sensor location: VW Golf B4 TDI 1Z (1993) Quote
@Bertil.
While I have an early B4 1Z (1.93), mine definitely does NOT have a speedometer cable.
On the left side of the gearbox, there is only the connector for the reverse lights. It only has 2 wires connected to it. The sensor must be located somewhere else... icon_confused.gif
Hermann.
Translated on 19-08-2026, 1:26.
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wo sitzt der "Geber für Geschwindigkeitsmesser"... Diesel Engine Technology
No new posts Speedometer calibration On-Board Diagnostics (OBD)
No new posts TEMPOMAT niedrigste Geschwindigkeit definieren On-Board Diagnostics (OBD)
No new posts Performance Issues at High Speed: Error 575 On-Board Diagnostics (OBD)
