Gear Oil Drain Plug: Location & How-To
flightmaster
Post20-02-2004, 13:07    Subject: Gear Oil Drain Plug: Location & How-To Quote
Hello everyone,
I'm planning to change the transmission oil in my Golf. But how do I get the old oil out?
Is there a bleed screw?
Golf 4, Engine code: ALH, 120,000 km[/b]
Translated on 30-09-2026, 17:34.
Post20-02-2004, 13:23    Subject: Gear Oil Drain Plug: Location & How-To Quote
There should be a large internal hexagon screw located at the bottom of the differential.
Translated on 30-09-2026, 17:35.
Post20-02-2004, 13:49    Subject: Gear Oil Drain Plug: Location & How-To Quote
http://people.freenet.de/golf-schrauber/getriebe.jpg
Release the "2" and then completely fill the "1".
This is a 02A transmission from a Volkswagen Golf 3 TDI.
A 17mm Allen key fits in there (you can even weld two wheel nuts together to make one!).
You don't have to buy the thing (like I did).
flightmaster
Post21-02-2004, 10:25    Subject: Gear Oil Drain Plug: Location & How-To Quote
Thank you very much... it starts this afternoon.
Translated on 30-09-2026, 17:36.
D.
Post07-03-2004, 17:44    Subject: Gear Oil Drain Plug: Location & How-To Quote
@flightmaster:
At what mileage did you change the oil?
Did you experience any difficulties beforehand?
Why did you decide to switch?
What type of oil did you use for the oil change?
If there were any transmission problems before, were they resolved afterward?
Is it easier to shift gears now?
Was was missing?
Thanks, and greetings from D., who is still considering having the transmission fluid changed.
JRoth
Post07-03-2004, 21:25    Subject: Gear Oil Drain Plug: Location & How-To Quote
Hello D.!
I had significant problems with my Passat 35i, 1Z, CTN, with 240,000 km, for example, difficulty shifting from idle to first gear at traffic lights. After a long hesitation, I changed the transmission oil (Castrol TAF X - which someone recommended in another forum). The new oil brought a significant improvement. A little later, I adjusted the cable-operated gear linkage, and since then, my transmission has been shifting optimally again! Forget about "lifetime fill" icon_mad.gif.
Sure, go ahead!
Passat Variant 35i 1Z 05/02 - 01/05
Ford Galaxy AFN 01/05 -07/06
Ford Galaxy 08/06 - 08/09
Translated on 30-09-2026, 17:38.
D.
Post08-03-2004, 18:17    Subject: Gear Oil Drain Plug: Location & How-To Quote
Thank you!
Then I guess I'll tackle that.
Best regards, D.
Translated on 30-09-2026, 17:39.
No new posts Injection Nozzles for ALH Engines Diesel Engine Technology
No new posts Which AHF fuel injectors? Diesel Engine Technology
No new posts What boost gauge? Diesel Engine Technology
No new posts Which spark plugs? Diesel Engine Technology
