tsfreak
08-09-2008, 13:19 Subject: Boost Lag & Soot: Causes and Solutions |
Hello!
Could someone please take a look at the log and let me know what might be causing the slow LD build-up or the soot formation at full load?
As far as I can tell, the smoke limiter is active. Is that possible? And if so, how do I fix it?
Lufi, new.
Diesel filter, new.
Vacuum system sealed (new hoses installed).
Thank you very much! Golf 4 TDI;6-Gang; PD; AJM; 85KW/115PS; 180t KM; AGR defekt; Saugrohr entdrosselt;
Translated on 28-09-2026, 18:54.
matthiasTDI96 Profi-Schrauber
08-09-2008, 14:13 Subject: Boost Lag & Soot: Causes and Solutions |
I am unable to access external URLs, so I cannot translate the text from the provided link. Please provide the text directly, and I will be happy to translate it for you.
Please organize the log.
Translated on 28-09-2026, 18:55.
tsfreak
08-09-2008, 14:33 Subject: Boost Lag & Soot: Causes and Solutions |
Sorry, I've uploaded it again as an xls file. I hope that's okay. Golf 4 TDI;6-Gang; PD; AJM; 85KW/115PS; 180t KM; AGR defekt; Saugrohr entdrosselt;
Translated on 28-09-2026, 18:56.
08-09-2008, 17:45 Subject: Turbo Lag & Soot: Troubleshooting Guide |
tsfreak wrote: | Could someone please take a look at the log and let me know if they can identify the cause of the slow LD build-up or the soot formation at full load?
As far as I can see, the smoke limit is active. | Could that be the case? And if so, how do I fix it?}By either having your chip tuner physically access the roof of the car, or by retrieving the original software. Gruß Ulf
Profile PM Garage |
tsfreak
08-09-2008, 22:58 Subject: Boost Lag & Soot: Causes and Solutions |
Thank you, Ulf, for your effort and your clear statement.
Sure, it's not software from a top-tier tuner. But could it be that it doesn't account for the faulty EGR valve, and that's why the problem is occurring? Golf 4 TDI;6-Gang; PD; AJM; 85KW/115PS; 180t KM; AGR defekt; Saugrohr entdrosselt;
Translated on 28-09-2026, 18:57.
09-09-2008, 6:22 Subject: Boost Lag & Soot: Causes and Solutions |
tsfreak wrote: | | Could it be that he didn't take into account the faulty EGR valve, and that's why the problem occurred? | Whether it's the standard configuration or "normally" tuned, if a defective EGR valve is "always closed," it cannot produce more soot than a functioning EGR valve.
I haven't looked into whether it would be possible to force the software to work in that way, because I don't have enough time to explore all the possible and unusual ways it could be misused.
As long as there isn't a mechanical defect causing excessive soot production, your black smoke is likely simply indicating the "quality" of the tuning software.
The LD (Lean Definition) setup wouldn't be faster even with an active (instead of blocked) EGR system; it would likely be even slower. The software offers various parameters that can be adjusted to improve the result, but if the tuner doesn't know what they're doing, they can actually make things worse.
Quote: | | No software from a high-end tuner | . With high-end tuners, you can only be sure of one thing: that you are financing their representative office / luxury building with the price you pay for the tuning.  Gruß Ulf
Translated on 28-09-2026, 18:59.
Profile PM Garage |
tsfreak
09-09-2008, 7:57 Subject: Boost Lag & Soot: Causes and Solutions |
Okay, I understand. I'll look into that colleague's behavior.
Anyway, now that I've solved several other problems, I know where I still need to take action. Golf 4 TDI;6-Gang; PD; AJM; 85KW/115PS; 180t KM; AGR defekt; Saugrohr entdrosselt;
Translated on 28-09-2026, 19:00.
09-09-2008, 10:57 Subject: Boost Lag & Soot: Causes and Solutions |
tsfreak wrote: | | I'm going to check out that colleague | a bit. :twisted:Getting work done by colleagues is cheap, but sometimes it's not even worth the price. } Gruß Ulf
Translated on 28-09-2026, 19:01.
Profile PM Garage |
tsfreak
10-09-2008, 7:20 Subject: Boost Lag & Soot: Causes and Solutions |
It's probably true.
However, I have one more question. I've noticed that when, for example, during a log run with boost pressures of 1200-4000, the boost is generally fine and there are no overshoots. However, during normal driving, these overshoots appear. For example, in 5th or 6th gear, the boost might reach 120 when accelerating quickly. So, when I suddenly press the accelerator.
Can you confirm this behavior? Is this normal, or is there something else wrong?
I had already adjusted the VTG rod as far as it would go, and the load distribution was perfect. There were no oscillations or overshoots. It was running great. I parked the car in the evening, and the next day I had excessive oscillations again. Could it be a temperature sensor? Golf 4 TDI;6-Gang; PD; AJM; 85KW/115PS; 180t KM; AGR defekt; Saugrohr entdrosselt;
Translated on 28-09-2026, 19:02.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2403 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
10-09-2008, 8:50 Subject: Boost Lag & Soot: Causes and Solutions |
Quote from the terms of service of this forum, found at: /faq.php.
/faq.php wrote: | | Questions about (...) other tuning products that are not (...) available from this online shop will be deleted without comment. Support for EBAY products or products from competitors is the responsibility of the respective seller. |
Therefore, we are now closing.
Translated on 28-09-2026, 19:03.
Profile PM Garage |
