vicky66
25-02-2023, 21:18 Subject: Audi 3.0 TDI CDUC Piston Endoscopic Inspection |
Hello, I removed my injectors yesterday to have them checked, as well as...
I looked into the combustion chamber with my endoscope camera.
Now I have 3 questions that remain unanswered.
Why do some pistons on the top side have no carbon deposits? (Image 5, 6)
2) Are the carbon deposits on the piston crown and cylinder wall normal, or are they harmful? (Images 1, 2, 3, 4, 7)
3) What do you say about the scratch marks on the cylinder wall? (See images 8 and 9).
The Audi was manufactured in 2014 and currently has almost 89,000 kilometers (approximately 55,000 miles) on the odometer.
I hope you can help me; thank you in advance.
| Description: |
| File size: |
250.2 KB |
| Viewed: |
617 times |
| Description: |
| File size: |
328.82 KB |
| Viewed: |
684 times |
| Description: |
| File size: |
426.06 KB |
| Viewed: |
613 times |
| Description: |
| File size: |
268.17 KB |
| Viewed: |
609 times |
| Description: |
| File size: |
270.41 KB |
| Viewed: |
632 times |
| Description: |
| File size: |
273.78 KB |
| Viewed: |
607 times |
| Description: |
| File size: |
385.82 KB |
| Viewed: |
610 times |
| Description: |
| File size: |
324.92 KB |
| Viewed: |
617 times |
| Description: |
| File size: |
290.26 KB |
| Viewed: |
616 times |
Translated on 15-07-2026, 14:18.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1509 Karma: +644 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
dieselschrauber likes this. |
25-02-2023, 21:49 Subject: Audi 3.0 TDI CDUC Piston Endoscopic Inspection |
Soot or lack thereof can be caused by differently functioning injectors...
The marks could be caused by moisture in the cylinder after a period of inactivity.
What are your oil change intervals?
Do you use branded or generic diesel fuel?
Translated on 15-07-2026, 14:19.
Profile PM Garage |
vicky66
25-02-2023, 22:49 Subject: Audi 3.0 TDI CDUC Piston Endoscopic Inspection |
Hello, thank you for your reply. Since I bought the car, about 10,000 km ago, I've mostly been using regular diesel at a Shell gas station.
I've now changed the oil change interval to a fixed interval of every 10,000 km. Previously, the car was serviced at Audi using the longlife interval.
And yes, the Audi is a summer vehicle, which means it will be idle for longer periods more often during the winter!
Translated on 15-07-2026, 14:20.
Herbert Profi-Schrauber
25-02-2023, 23:45 Subject: Audi 3.0 TDI CDUC Piston Endoscopic Inspection |
Hi there,
Is there a problem with the vehicle?
Translated on 15-07-2026, 14:21.
vicky66
26-02-2023, 7:43 Subject: Audi 3.0 TDI CDUC Piston Endoscopic Inspection |
"No, there are no problems with the car. I just wanted to have the injectors checked and hear your opinions on whether anything looks problematic."
Translated on 15-07-2026, 14:22.
26-02-2023, 10:00 Subject: Audi 3.0 TDI CDUC Piston Endoscopic Inspection |
It's impossible to avoid marks inside the cylinder. The best approach is to run the engine thoroughly hot before storing it for the winter and then turning it off, avoiding any further use in between.
When my father used to winterize the Claas Columbus combine harvester, he would insert oily rags into the exhaust pipe and the air filter connection.
I would now remove the glow plugs, clean them, and reinstall them with ceramic paste on the threads, possibly replacing them if necessary. Be sure to observe the specified torque when tightening.
Translated on 15-07-2026, 14:23.
Profile PM Garage |
26-02-2023, 10:05 Subject: Audi 3.0 TDI CDUC Piston Endoscopic Inspection |
Hi there,
Using VCDS, it is standard practice to first check the engine running hours and then examine any deviations in the injector timing.
If everything is normal, you generally don't do anything else, unless you have too much time and money.
Translated on 15-07-2026, 14:24.
vicky66
26-02-2023, 10:23 Subject: Audi 3.0 TDI CDUC Piston Endoscopic Inspection |
Thank you for your answers.
Actually, my intention was only to replace the copper sealing rings of the injectors, as these tend to fail and leak in engines. So, I also sent the injectors for inspection and had an endoscopic examination performed.
So, you're saying that these small deposits of soot, as seen in images 1, 2, 3, and 4, don't pose a significant problem?
Translated on 15-07-2026, 14:25.
26-02-2023, 10:36 Subject: Audi 3.0 TDI CDUC Piston Endoscopic Inspection |
It is important to carefully clean the area where the burner nozzles are located.
In my opinion, soot from diesel engines is normal.
Profile PM Garage |
26-02-2023, 10:44 Subject: Audi 3.0 TDI CDUC Piston Endoscopic Inspection |
Quote: | | My intention was actually just to replace the copper sealing rings of the injectors, because they tend to fail and leak in engines. |
Sind bei mir nach 170000 km immer noch dicht. Meaningless action.
Translated on 15-07-2026, 14:26.
26-02-2023, 11:28 Subject: Audi 3.0 TDI CDUC Piston Endoscopic Inspection |
"Leaks sometimes occur in the V6 engines."
Let's do everything right this time and enjoy peace for the next 5 to 10 years.
Translated on 15-07-2026, 14:27.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
26-02-2023, 22:10 Subject: Audi 3.0 TDI CDUC Piston Endoscopic Inspection |
vicky66 wrote: | Thank you for your answers.
My intention was simply to replace the copper sealing rings of the injectors, as they tend to fail and leak in these engines. Therefore, I also sent the injectors for inspection and had an endoscopic examination performed.
Also meint ihr diese Rußhäufchen wie auf Bild 1,2,3,4 zu sehen stellen auch kein großes Problem da ? |
It makes no sense to remove injectors that are in good condition and functioning properly.
"IF an injector seal was leaking, I would only address that specific cylinder. For the rest, I would check if everything is sealed properly (which depends on the design of the cylinder head to see if that's easily possible) or verify the torque of the injector hold-downs."
Tight fit = no problem with the sealing ring.
Die Cu-Dichtringe gehen auch nicht "einfach so" kaputt, sondern weil der Injektor nicht richtig an den ZK gepresst wird, ergo der Halter nicht fest ist.
Translated on 15-07-2026, 14:28.
Profile PM WWW Garage |
vicky66
26-02-2023, 23:28 Subject: Audi 3.0 TDI CDUC Piston Endoscopic Inspection |
Okay, thank you. However, I have one more question: What is the best way to identify a leaking injector?
Translated on 15-07-2026, 14:29.
27-02-2023, 9:32 Subject: Audi 3.0 TDI CDUC Piston Endoscopic Inspection |
You'll notice it with starting difficulties when the rail pressure is low. Otherwise, the next day after stopping the engine, you can use an endoscope to check if the injector and combustion chamber are wet by drilling a hole in the glow plug housing.
Regarding the issue of leaking fuel injectors, we once had a company-owned Mercedes-Benz Vito 108 CDI with less than 100,000 kilometers on the odometer, and all of its fuel injectors were leaking.
Translated on 15-07-2026, 14:30.
Profile PM Garage |
27-02-2023, 9:56 Subject: Audi 3.0 TDI CDUC Piston Endoscopic Inspection |
Rüdi wrote: | You'll notice it with starting difficulties when the rail pressure is low. Otherwise, you can check the next day after stopping the engine by drilling a hole in the glow plug and using an endoscope to see if the injector and combustion chamber are wet.
Neither of those options seems sensible.
The first signs would be irregularities in the engine's running and a pungent smell from the exhaust.
During a systematic inspection, one examines the flow stability, switching time variations, return flow rates, and, if there is suspicion of a leaking nozzle, the pressure drop.
Can we finalize it then?
Translated on 15-07-2026, 14:32.
