Diesel Exhaust System: Conversion Guide
Devilseye
Post14-03-2004, 16:16    Subject: Diesel Exhaust System: Conversion Guide Quote
'Since I want to try a few things, I'd like to install an exhaust system (original from the catalytic converter onwards) on my all-wheel-drive TDI. The system is from a VR6 4motion naturally aspirated engine, and while the pipe diameter is larger and the muffler is slightly bigger, the mounting points are the same.'
Now, my actual question: Are there any potential problems with backflow or anything else that could cause damage to the turbocharger?
Are there any other issues with that?
I would be grateful for some tips!
Translated on 23-09-2026, 8:03.
konjoy
Post14-03-2004, 20:46    Subject: Diesel Exhaust System: Conversion Guide Quote
I'm not aware of any problems. The catalytic converter is causing the back pressure. If the exhaust pipe is a bit larger, it really won't make much of a difference. There are also sports exhaust systems for diesel engines. However, you shouldn't expect a performance increase. Even if you remove the exhaust pipe completely after the catalytic converter, it won't get particularly loud, and there won't be any noticeable performance gains. The only thing that might happen is that the turbocharger reaches its operating speed faster, which doesn't change the boost pressure and therefore doesn't affect the power. The engine might respond a bit quicker, and the turbocharger might be under more stress. But that's only if you drive without any exhaust pipe after the catalytic converter. If the diameter of the exhaust pipe after the catalytic converter is slightly larger, it won't have any noticeable effect.
Translated on 23-09-2026, 8:04.
Devilseye
Post14-03-2004, 23:10    Subject: Diesel Exhaust System: Conversion Guide Quote
Okay, great, then it's perfect. Thank you!
As I mentioned, I was a bit worried that the backflow might have been larger than expected, which could have caused problems.
Translated on 23-09-2026, 8:05.
Arne
Post15-03-2004, 10:01    Subject: Diesel Exhaust System: Conversion Guide Quote
I also have the original exhaust system from the G60 on my AFN.
Traveled safely. No problems occurred.
arne
Translated on 23-09-2026, 8:06.
Devilseye
Post15-03-2004, 11:07    Subject: Diesel Exhaust System: Conversion Guide Quote
Okay, I believe that. It's a motor with a turbocharger, after all. But my main question is whether it would be different for a naturally aspirated engine?
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Doku Transporter 7DK2H2, Abgasanlage gebrochen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel vs. Gasoline: Which is Best? Transmission, Chassis, Body & Interior
No new posts Die Ölfrage: Eigenschaften für Benziner und Diesel Diesel Engine Technology
No new posts Hilfe! 1,6 Benziner klingt wie ein Diesel Diesel Engine Technology
No new posts Polo diesel with a gasoline transmission??? Diesel Engine Technology
