Golf IV Tiptronic: Max. Torque & 5-Speed Options
krümmel
Post17-03-2004, 18:09    Subject: Golf IV Tiptronic: Max. Torque & 5-Speed Options Quote
Transmission code: GNY; Engine type: ASZ (96 kW).
I need the gear ratios and axle drive ratios.
What is the maximum torque for which the transmission is suitable?
Okay, bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Thank you.
Crumbs.
Translated on 23-09-2026, 7:34.
krümmel
Post19-03-2004, 19:17    Subject: Golf IV Tiptronic: Max. Torque & 5-Speed Options Quote
Does anyone here actually know anything? There must be some information available somewhere.
Crumbs.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post21-03-2004, 17:15    Subject: Golf IV Tiptronic: Max. Torque & 5-Speed Options Quote
It's just a regular automatic transmission.
They should theoretically be able to reach up to 700nm.
B.Eng (FH) u. KFZ Meister
Translated on 23-09-2026, 7:35.
Post21-03-2004, 21:56    Subject: Golf IV Tiptronic: Max. Torque & 5-Speed Options Translating...
[Translating...]
Gremlin
Post22-03-2004, 9:23    Subject: Golf IV Tiptronic: Max. Torque & 5-Speed Options Quote
It's just a normal automatic transmission.
they should actually be able to go up to 700nm, !
Okay, that planet set might take a while to assemble...
'But clutches, brake bands, and definitely not the WK.'
Without electronic adjustments, nothing will work because the transmission would otherwise be operating at too low torque levels, and the control pressures would not be raised sufficiently.
CU Gremlin.
krümmel
Post22-03-2004, 18:22    Subject: Golf IV Tiptronic: Max. Torque & 5-Speed Options Quote
Without electronic adjustments, nothing will work because the transmission would otherwise be subjected to too low torque, and the control pressures would not be raised sufficiently.
CU Gremlin
...well, at least 370nm are possible without any changes to the control system.
How about the translations, does anyone have any insights?
Thank you and best regards.
Crumbs.
Translated on 23-09-2026, 7:37.
No new posts Torque and driving fun in everyday life Technical Articles
No new posts Diagrams of Torque/Power with VCDS/VAG-COM Technical Articles
No new posts VAG 1.8L R4/5V 125hp (92kW) Naturally Aspirated Gasoline ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf Tiptronic: Info & Steering Wheel Paddles Diesel Engine Technology
No new posts Tiptronic On-Board Diagnostics (OBD)
No new posts Problem Afb + Tiptronic Diesel Engine Technology
No new posts Tiptronic: 4-Cylinder Engine Performance Diesel Engine Technology
