Golf 4 Speedometer: Current Speed Flips Up and Down
Dan.jel
Post17-03-2004, 0:59    Subject: Golf 4 Speedometer: Current Speed Flips Up and Down Quote
Hello!
Yesterday morning, on my way to work, I noticed that the speedometer needle was constantly fluctuating up and down.
The digital display in the Climatronic system is malfunctioning in the same way!
So, I'm guessing/hoping that it's not the combination instrument, but rather a sensor! The fuel level, temperature, and RPM are working normally, as usual!
What exactly do I need to replace now?
Distance sensor or something else?
Daniel.
Translated on 03-09-2026, 3:00.
Post17-03-2004, 8:05    Subject: Golf 4 Speedometer: Current Speed Flips Up and Down Quote
It sounds strange. I once had a weasel that chewed on the cable of a sensor. After I repaired the cable myself, everything worked again. My tip: maybe there's a damaged cable somewhere! Otherwise, I also think the sensor is likely to be the culprit!
Translated on 03-09-2026, 3:01.
joergs
Post17-03-2004, 8:17    Subject: Golf 4 Speedometer: Current Speed Flips Up and Down Quote
I think I've seen this before. My Passat had a similar issue recently. In my case, it was the mileage sensor. However, I also agree with the person who posted before me; it could also be a badger or some kind of moisture.
No new posts P3366 - System pressure (gas): too high Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P244B - Diesel Particulate Filter - Differential Pressure... General Tips
No new posts P2185 - Coolant Temperature Sensor, High Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. TDI Golf: 115 PS to 150 PS Upgrade Diesel Engine Technology
No new posts Golf 4: Location of Distance Sensor Diesel Engine Technology
No new posts Does this connector fit a Volkswagen Golf 4? On-Board Diagnostics (OBD)
No new posts VW Golf 4: Replace Analog Speedometer with FIS Display Transmission, Chassis, Body & Interior
