palmstrollo Guest
10-03-2004, 15:54 Subject: B4 Tie Rod: Function & Purpose Explained |
Hi.
After receiving a suggestion in another thread, where I had mentioned the possibility of a broken tie rod end or a defective strut mount, I received a comment pointing to a potential defect in the stabilizer link.  This led me (and now you) to question the purpose or function of these stabilizer links.
So: What is the purpose of the tie rod, and how does it work? What are the symptoms of a faulty tie rod? How is it replaced?
If anyone has photos of that, it would be great.
Thank you and best regards.
Hermann.
Translated on 08-10-2026, 3:51.
Wolfgang Guest
10-03-2004, 18:19 Subject: B4 Tie Rod: Function & Purpose Explained |
The stabilizer bar connects to the wheel suspension via a tie rod.
The stabilizer is a U-shaped 'rod' that counteracts the tendency of a wheel to dip in on one side, while not significantly hindering the normal, even dipping on both sides. This helps to counteract the vehicle's tendency to lean outwards in curves.
In earlier models (e.g., Golf 1 and 2), the stabilizer (as it is affectionately called  ) was simply attached to the lower control arm and the lateral links.
In the current models, it is located higher up in the engine compartment and is connected to the wheel suspension (specifically, to the shock absorber located below the spring) via tie rods.
Translated on 08-10-2026, 3:52.
palmstrollo Guest
10-03-2004, 18:36 Subject: B4 Tie Rod: Function & Purpose Explained |
Hi Wolfgang.
Okay, so it's just a different type of mounting compared to the 'old' rubber bushings found in cars like the Golf. It definitely has nothing to do with my problems when starting the car.
Thank you.
Hermann.
Translated on 08-10-2026, 3:54.
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
10-03-2004, 22:22 Subject: B4 Tie Rod: Function & Purpose Explained |
palmstrollo wrote: | | That definitely has nothing to do with my problems when starting. |
I would also say that... ____________
Kein Auto mehr!
Julian Guest
11-03-2004, 10:18 Subject: B4 Tie Rod: Function & Purpose Explained |
Hmm, so, Hermann...
Okay, here's a simple question/equation:
B4 + Winter tires + outdoor temperature around 0°C + wet conditions = traction problems.
Do you think that will work, before you realize that your volume knob on the radio is underweight...?
Translated on 08-10-2026, 3:55.
palmstrollo Guest
11-03-2004, 10:31 Subject: B4 Tie Rod: Function & Purpose Explained |
@Julian
'Smart aleck. No one will be surprised if he experiences traction problems when starting off and accelerating hard with this setup.'
However, if even gentle acceleration in wet conditions causes the front wheels to spin (which was already a problem during the summer!), then that's definitely something worth investigating, right?
I believe I also expressed that in the relevant thread.
Hermann.
Translated on 08-10-2026, 3:56.
Julian Guest
11-03-2004, 16:02 Subject: B4 Tie Rod: Function & Purpose Explained |
@Julian
'Smart aleck. No one will be surprised if he experiences traction problems when starting off and accelerating quickly with this setup.'
However, if even gentle acceleration in wet conditions causes the front wheels to spin (which was already a problem in the summer!), then that's definitely something worth investigating, right?
Hermann
Hm, you're the one who's being a jokester, but I guess there has to be someone like that.
What kind of tires are you using (size, brand)?
Translated on 08-10-2026, 3:57.
palmstrollo Guest
11-03-2004, 16:29 Subject: B4 Tie Rod: Function & Purpose Explained |
Tire size 205/60, mounted on a 10-spoke series wheel. These are Barum budget tires.
Why?
However, this problem has also been occurring for 1 1/2 years, even with winter tires or Uniroyal summer tires.
Translated on 08-10-2026, 3:58.
faz Blaumann
1994 Audi 80 Premium Support
17-03-2004, 21:27 Subject: B4 Tie Rod: Function & Purpose Explained |
Should I retrofit EDS?
With the ABS/EDS unit and the corresponding ABS control module, you should be able to find a solution. Perhaps you can find a used one. MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 08-10-2026, 3:59.
Profile PM Garage |
