VAG-COM baud rate cannot be synchronized
metalbrother
Post16-02-2004, 16:41    Subject: VAG-COM baud rate cannot be synchronized Quote
Hi!
I know I'm a bit slow, but I have another question.
When I run the loopback test, I get a consistent baud rate of 57600. However, when I connect the cable to the car, I first get a message indicating that everything is working, then a message saying that the adapter was not found, then a message saying that the device is unknown, and so on... (it keeps changing like a random number generator).
'And then, if it finally works and I connect to a control unit, I get the message that it can't synchronize the baud rate.'
It might depend on the shielding, as my cable to the car is about 3 meters long and has no shielding.
Maybe you know what might be causing that.
metalbrother
Post16-02-2004, 18:30    Subject: VAG-COM baud rate cannot be synchronized Quote
Vehicle: Audi A4 B5, 1996, Quattro, 2.8 gasoline engine, 200 horsepower.
Hardware: Interface by Mark Neugebauer, using a Max232 chip.
Search function: Yes, but the problem lies elsewhere.
I probably thought that the missing shielding in the cable might be causing external interference to induce signals that make the signal unusable, or something like that.
maxx022
Post19-03-2004, 17:04    Subject: VAG-COM baud rate cannot be synchronized Quote
Vehicle: Audi A4 B5 1996 Quattro 2.8 gasoline engine with 200 horsepower.
Probably, I thought that the signal was becoming unusable due to foreign induction in the cable, caused by a lack of shielding.
Hello!
I've experienced this problem too!
This is due to the connector itself, as it is not equipped with automatic baud rate detection.
Make sure to set it to auto-baud rate detection, and it should work.
Sincerely, Maxx.
Karma: +805 / -0   Thank you, like it!
Post19-03-2004, 19:30    Subject: VAG-COM baud rate cannot be synchronized Quote
Okay, I understand. Please provide the German text you want me to translate.
http://shop.dieselschrauber.de/product_info.php/products_id/46{MARKER}http://shop.dieselschrauber.de/product_info.php/products_id/329
metalbrother
Post20-03-2004, 22:00    Subject: VAG-COM baud rate cannot be synchronized Quote
aha thxl
'But is there no way I can still use my interface? Because I've already invested some money and time into it, and it would be a shame if it all went to waste?'
And also, an interface costing 400€ wouldn't be worth it for me, as I would use it far too infrequently.
Well, thanks anyway.
Best regards, Patrick.
Post21-03-2004, 11:12    Subject: VAG-COM baud rate cannot be synchronized Quote
Have you ever experimented with the K/L - K1/K2 switch?
Tried different baud rates?
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG COM: Baud rate synchronization failed... On-Board Diagnostics (OBD)
No new posts Replacement key cannot be adjusted? On-Board Diagnostics (OBD)
No new posts VCDS MicroCan: Can't Edit Adaptation Channel On-Board Diagnostics (OBD)
No new posts SEO: Best Practices for Website Optimization Diesel Engine Technology
